Using SD Card Slot on ME3600X
Nils 86
we are trying to use the SD Card Slot on an Cisco ME3600X (ME-3600X-24FS-M) IOS Version 15.2(4)S2.
If i try to copy a file from the sd card slot to the flash there is no Option like "slot0:" or something alse
and no syslog message appers while adding the SD Card.
Cat3600#copy ?
  /erase          Erase destination file system.
  /error          Allow to copy error file.
  bs:             Copy from bs: file system
  cns:            Copy from cns: file system
  flash:          Copy from flash: file system
  ftp:            Copy from ftp: file system
  http:           Copy from http: file system
  https:          Copy from https: file system
  logging         Copy logging messages
  null:           Copy from null: file system
  nvram:          Copy from nvram: file system
  rcp:            Copy from rcp: file system
  running-config  Copy from current system configuration
  scp:            Copy from scp: file system
  startup-config  Copy from startup configuration
  system:         Copy from system: file system
  tar:            Copy from tar: file system
  tftp:           Copy from tftp: file system
  tmpsys:         Copy from tmpsys: file system
  xmodem:         Copy from xmodem: file system
  ymodem:         Copy from ymodem: file system
Can anyone help me?
kind regards
Nils
5 Replies 5
InayathUlla Sharieff
Hi Nils,
SD Flash is currently not supported. The feature is in roadmap. The image
which is going to support it is 15.3(2)S, which is going to be released
Q1CY13
Inayath
*Plz rate if this is helpfull.
Hi Inayath,
thx you for answer, its very helpful!!
Nils
Hi Inayath,
Does this include the ME3800X?
Hi Leo,
Yes same applies for ME3800X models as well.
Inayath
Hi Inayath,
Looking forward to this.
