Using VRF to span VLAN (separate Layer 2 traffic via a Layer 3 switch)
Bryan
VLAN400  10.225.16.0/24 and this VLAN400 must be separated from all other traffic within the network.
And this VLAN400 shares the same broadcast domain cross the entire network.
Firewall Switch(10.225.16.254)---------trunk-------------SWB--------------trunk-------------SWC-------trunk---------SW-1 VLAN400 (10.225.16.11)
This is easy to achieve, trunking between all switches, the VLAN400 will be passing through without any issues.
Firewall Switch(10.225.16.254)---------trunk-------------SWB---------------WAN-------------SWA--------trunk----------SW-2--------VLAN400 (10.225.16.10)
The challenging how could I pass the same VLAN traffic from SWA to Firewall Switch through a WAN link to SWB?
I am stumped by this, seems VRF lite can resolve this issue, but no idea how to implement it. The requirement is using Layer 3 method to do this.
Could someone shed some light on this? It would be highly appreciated. Cheers, Bryan
7 Replies 7
Reza Sharifi
You basically trying to configure layer-2 between all switches? If that is the case and the WAN provider is handing off a layer-2 Ethernet connection, you can simply trunk the WAN connection and add vlan 400 to it.
Thanks Reza for your prompt reply.
Certainly we can trunk the WAN connection and add VLAN 400 to it as you mentioned.
However according to our past experience, we constantly see UDLD failure which turns the Layer 2 traffic down. That's the reason we want to use Layer 3 approach this time.
The UDLD issue you have seen is from the provider's site of the connection?
If that is the case, you can contact them so they can look into fixing the issue.
If the UDLD issue is from your site, you can configure UDLD protection on your switches. See link:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst6500/ios/12-2SX/configuration/guide/book/udld.html
Thanks Reza. But the management wants to use Layer 3 to accomplish this implementation. Otherwise my life will be whole lot easier :)
I understand :)
Here is document on using layer-2 over a layer-3 network.
Have a look and see if it can be done in your environment.
As you probably already know extending one vlan between multiple sites is not really best practice, but if your management insist in wanting vlan 400 everywhere than you may not have a choice.
here is the link:
http://www.cisco.com/c/en/us/td/docs/ios/12_0s/feature/guide/l2tpv30s.html
Good Luck
Really appreciated Reza :) Big thanks for you.
I don't think our platform 6506 and 6509 can support L2TPv3.
Any idea how to implement VRF Lite to achieve this?
B
B
