using vrfs with eigrp
faghouri83
Hi Everyone
I need to get two vrfs configured on some 3750 switches. I started off by configuring one vrf on three switches, A connected to B and B connected to C. The config was very simple like below but it didnt work:
switch a example:
ip vrf admin
rd 100:1
route-target import 100:1
route target export 100:1
interface gigabitethernet 1/0/24
ip vrf forwarding admin
ip address 1.1.1.1 255.255.255.252
router eigrp 100
network 1.1.1.0 0.0.0.3
The rest of the config for switches B and C were configured the same. I could ping the next hop but I couldnt ping from switch A to C.
Now I found another guide on the internet and it had additional configuration that I needed to add to eigrp. So I configured:
router eigrp 100
address-family ipv4 vrf admin
network 1.1.1.0 0.0.03
Now i tried to add the command:
autonomous-system 100
However my switch wont accept this command even though the switch gives me a warning that i need to configure an autonomous system number.
My question is,am i on the right path here? and also why isnt my switch taking this command? the switch ios is 15 and its a universalk9.
Thanks for your help
Reza Sharifi
You may need IP services license.
What is your license level?
sh license or sh ver
I have a permanent ip services licence on there
regards
Can you try configuring the autonomous system on the same line as eigrp as address-family ipv4
Example,
router eigrp 100
address-family ipv4 vrf admin autonomous-system 1
