Need ASA 9.x Etherchannel example w/ layer 2 switch config
corpengineer818
Hello there:
Could anyone please point me to example configurations of Etherchannel on an ASA 9.x, connecting to a layer 2 switch?  I need to see how the switch is configured as well.
Thank you.
Marvin Rhoads
It's pretty simple - follow these guides:
ASA Configuration
Switch configuration
The second link is for a 4500 series switch but the concept is the same for most Layer 2 Catalyst switches running IOS or IOS-XE.
Mizanul Islam
I have configured Port channel with Cisco 2960S switch. Here is the below configuration example. If the answer is correct please Comments.
fw-01# sho port-channel summary
Flags: D - down P - bundled in port-channel
I - stand-alone s - suspended
H - Hot-standby (LACP only)
U - in use N - not in use, no aggregation/nameif
M - not in use, no aggregation due to minimum links not met
w - waiting to be aggregated
Number of channel-groups in use: 1
Group Port-channel Protocol Span-cluster Ports
11 Po11(U) LACP No Gi0/1(P) Gi0/0(P)
interface GigabitEthernet0/0
description *** Connected to CORE-SW-01 ***
channel-group 11 mode passive
no nameif
no security-level
no ip address
interface GigabitEthernet0/1
no nameif
no security-level
no ip address
interface Port-channel11
description *** Connected to CORE-SW ***
nameif outside
security-level 100
ip address 10.98.8.90 255.255.255.248 standby 10.98.8.91
================Switch====================
interface Port-channel12
description *** Port-Channel Used for DC-INSIDE-FW-1-IPS***
switchport access vlan 912
interface GigabitEthernet1/0/21
description **** inside Firewall 01 ***
channel-protocol lacp
channel-group 12 mode active
Please let me know your topology.
corpengineer818
Sorry, I should have provided more information. We would like to setup VLANs throughout, and within the etherchannel. The ASA 5545 is new, but the stack of Catalyst 3850's won't arrive for a bit. So For the time being, I have to connect the ASA to an existing layer 3 Netgear gsm7328s, which supports ether channel, and a few other layer 3 Foundry switches, 648p units, and an hp Procurve layer 3. The existing setup is messy. Not all traffic would go through the ether channel, but I would like the VLANs to span all the switches if possible. Thank you for the feedback.
