VACL design question
mahesh18
Level 6
Level 6
Hi everyone,
I have question here about VACL.
I have 2 - 3550 switches running HSRP.
They have vlan 10,20 and 30 configured.
3550A is Active for vlans 10,20 and 30.
3550A then connects to layer 2 switches A and B.
Layer 2 Switch A has vlan 10
Layer 2 switch B has vlan 20.
These switches connect to Router for Internet.
Vlan 10 subnet is   192.168.10.0
Layer 2 switch A  IP  192.168.10.5
I was configuring VACL to test so that from 3550A switch under vlan 10 I should not be able to telnet layer 2 switch A IP which is vlan 10.
Rest everything should work fine.
I did config the vacl and applied it but I was unable to ping or telnet to IP 192.168.10.5.
Also i was unable to ping the 3550B switch vlan 10 which is standby 192.168.10.2
Is there something wrong I am doing need to confirm with you guys?
Config I applied to 3550A
3550SMIA(config)#ip access-list extended telnet
3550SMIA(config-ext-nacl)#deny tcp 192.168.10.0 0.0.0.255 eq 23 192.168.10.5 ?
A.B.C.D Destination wildcard bits
3550SMIA(config-ext-nacl)#$2.168.10.0 0.0.0.255 eq 23 192.168.10.5 0.0.0.0
3550SMIA(config-ext-nacl)#permit ip any any
3550SMIA(config)#vlan access-map switch 10
3550SMIA(config-access-map)#match ip address telnet
3550SMIA(config-access-map)#action drop
3550SMIA(config-access-map)#vlan access-map switch 20
3550SMIA(config-access-map)#action forward
3550SMIA(config-access-map)#end
3550SMIA#config t
3550SMIA(config)#vlan filter switch vlan-list 10
3550SMIA(config)#end
MAhesh
Message was edited by: mahesh parmar
15 Replies 15
Hi Giuseppe and John,
Thanks for explaing we in the detail.
VACL is working as expected.
Best regards
Mahesh
