Need suggestion to upgrade IOS
Hi All,
In our environment we have total 18 Access Switches  and one Core Switch 6509 (s72033_rp-IPSERVICESK9-M), Version 12.2(18)SXE5, for the core switch i have to upgrade the IOS
All Access  switches are 3750 module with PoE
For ground floor Three switches
1    Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
2    Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
3   Model number : WS-C3750-48PS-S   Version ID : V10   IOS : 12.2(25)SEB4 C3750-IPBASE-M
And another one is WS-C3750G-48PS-S(connected with fiber to core Switch)
4   Model number : WS-C3750G-48PS-S   Version ID : V06   IOS : 12.2(35)SE5 C3750-IPBASE-M
For the First floor we have only one switch
5    Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
For the Second floor we have three switches with stack
6    Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
7   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
8   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
For the third floor we have three switches with stack
9    Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
10   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
11   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
For the fourth floor we only one switch
12   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
For the fifth floor we have two switches with stack
13   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
14   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
And another connected with UTP WS-C3750G-48PS-S
15   Model number : WS-C3750G-48PS-S   Version ID : V06   IOS : 12.2(35)SE5 C3750-IPBASE-M
And the last sixth floor we have three switches with stack
16    Model number: WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
17   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
18   Model number : WS-C3750-48PS-S   Version ID : V05   IOS : 12.2(25)SEB4 C3750-IPBASE-M
All are in default Vlan with basic configuration
Now my job is to upgrade the IOS and Create the vlan’s , as floor wise ,  my management told me IOS should be Same in all access switches ,
my question is which IOS version     I should upgrade which one is suitable for my devices ,
c3750e-ipbasek9-tar.150-1.SE3.tar                           Cisco Catalyst 3750E-48TD-E Switch
c3750e-ipbasek9-tar.122-58.SE2.tar                         Cisco Catalyst 3750E-48PD-E Switch
c3750e-ipbasek9-tar.122-55.EY.tar                           Cisco Catalyst 3750E-48PD-EF Switch
    Cisco Catalyst 3750E-48PD-S Switch
    Cisco Catalyst 3750E-48PD-SF Switch
    Cisco Catalyst 3750E-48TD-S Switch
After upgrading the IOS I have to Create Vlan’s and some do some configurations also
Thanks in Advance for the community Support
Reza Sharifi
Hi Aman,
122-58 is pretty good, but you should read the release notes to make sure there are no major bugs.  If your switches are stacked, you can use the .tar file to upgrade.  If they are not stacked than you can use .bin file to upgrade.
If you are planning to provide a vlan per floor than you can use the floor number:
example:
1st floor 10
second floor 20
3rd floor 30
and so on.
