VACL Question
theinfocentral
Community Member
Can someone please explain what the 10 represent on the access-map? If this is the vlan maping, i don't have vlan 10.
vlan access-map RSPAN-VACL 10
match ip address TCP_Connection
action forward
vlan filter RSPAN-VACL vlan-list 999
Steve
Martin Parry
Level 8
Level 8
The 10 is the sequence number. it allows you to specify differen't criteria within your access-map. For instance you may want to specify another set of criteria under sequence number 10.
Sorry that didn't make any sense.
You may be matching certain criteria within sequence number 10, then you may match against other criteria sequence 20.
Can you give me config example of the different criteria?
