Variance
How does variance help in EIGRP load balancing ? How do we decide on the variance value & where do we configure this ? why would we require "trafic share min" since it's equivalent to having no variance configured ?
6 Replies 6
Jon Marshall
Variance is used when you have more than one route to a destination but they are not equal cost eg.
Link 1 = 128Kbps
Link 2 - 256Kbps
Under default settings EIGRP would only use Link 2. if you configure a variance eg.
router eigrp 1
variance 2
then EIGRP will now use both links and for every 2 packets sent on Link 2 it will send one on link 1.
The traffic-share min command if applied to the above example would ensure that EIGRP only used Link 2.
Jon
Thanks for your quick reply Jon!
So, this would help in load balancing right ?
How would work on a scenario with 3 paths between router A and B with metric / bandwidth of 1.4Mb, 2.48Mb & 4.09Mb? How do we implement Variance here ?
You would need a variance value of 3 to allow EIGRP to use all 3 links in it's forwarding.
Jon
what does the variance value depend on? On the number of links that participate in the load sharing / balancing?
No its worked out from the bandwidths, so from your example
With a variance of 2 EIGRP would only use the 2.48Mb and 4.09Mb links - why
2.48 x 2 = 4.96 which is greater than 4.09
1.4 x 2 = 2.8 which is less then 4.09
so the 1.4Mb link would not be used but
3 x 1.4 = 4.2 which is greater than 4.09.
Jon
Thanks a lot Jon. I gotthe concept.
