VCAl to limit communication between devices in same vlan?
darrenriley5
hi,
Could I use a vacl to deny two devices in the same vlan and connected to the same switch (65000) to communicate with each other and permit communication between all other devices in that vlan.
Darren
Jon Marshall
darrenriley5 wrote:
hi,
Darren
access-list 101 deny ip host 192.168.5.10 host 192.168.5.11
access-list 101 deny ip host 192.168.5.11 host 192.168.5.10
access-list 102 permit ip any any
vlan access-map vfilter 10
match ip address 101
action drop
vlan access-map vfilter 20
match ip address 102
action forward
Jon
Jon Marshall
darrenriley5 wrote:
hi,
Darren
action drop
action forward
Jon
VLAN ACL is not same as Access List .
VLAN ACL is not associated with any interface & The behaviour of VLAN ACL is different from Access List.
VLAN ACL can Drop the traffic that passess through switch & Create same seq to pass rest of traffic,
We can't create an ACL that  say permit 2 users & Deny 10 users.It won't work. You have to define that which user should be droped.
So to work properly you should define correct access list.
It is same as route-map , where you match the Access List & Define that whether that will be Drop or Forward or Redirect.
For More detail you can refer  the below Link
http://www.cisco.com/en/US/docs/switches/datacenter/sw/4_1/nx-os/security/configuration/guide/sec_vlanacls.pdf
Chetan Kumar
