vdc out of band management
yingwangtoronto
I saw this digram from Cisco,but no configuration example. Right now I have nexus 7010 with sup 2 version 6.2.2. I could not assign the interface mgmt 0 to the different VDC. Do anyone do out of band management for VDCs? or can anyone let me know how could I configure the out of band management for vdc?
Thanks a lot.
pille1234
Level 3
Level 3
There's nothing special to configure. You don't need to assign the mgmt0 to a vdc, it belongs to every vdc right from the start. Just configure a seperate IP for every context.
pille
Hi Pille,
Thanks for your reply. I switch to the vdc and I did not find the "int mgmt0" in these VDCs, the mgmt0 only exists in the system VDC. In this case, I do not know how to configure the seperatt IP for every context. Could you share with me more details for the configuration?
Ying Wang
I know you do not see this interface in "sh run" command but you can add this configuration:
conf t
int mgmt 0
ip address x.x.x.x/x
vrf member management
no shut
try again sh run and you will see the interface management configuration.
