Verifying manual Switch-Switch MACSec configuration is working on 6880
Gagandeep Singh
Hi Team,
I need to find a way to determine if MACSec is working properly between two switches, or help understanding the output of the commands below to determine if it is working properly  on cat 6800.
Refer me a document which shows encrypted traffic or any commands.
Thanks in Advance.
Gagan
kilcreas
I've sent your question to the internal MACsec alias, and will put the response here (if I get one).
I got the Answer
It's " show cts macsec counters interface <>" that will tell us encrypted and protected packets.
