verifying portchannel configuration
Rahmat Ullah
I recently joined a company as a network engineer, most of the networking task has been implemented by previous employee. I'm looking into configuration of the network. lots of portchannel is being already implemented.
I'm looking for a command to see the whole properties of a specific portchannel for instance vlan membership, speed, mode etc...
Cisco Freak
Level 4
Level 4
This should help you out.
Switch#show etherchannel summary
Flags:  D - down        P - bundled in port-channel
        I - stand-alone s - suspended
        H - Hot-standby (LACP only)
        R - Layer3      S - Layer2
        U - in use      f - failed to allocate aggregator
        M - not in use, minimum links not met
        u - unsuitable for bundling
        w - waiting to be aggregated
        d - default port
Number of channel-groups in use: 1
Number of aggregators:           1
Group  Port-channel  Protocol    Ports
1      Po1(SD)         LACP      Fa0/8(I)    Fa0/9(I)
Switch#sh etherchannel port-channel
Channel-group listing:
Group: 1
Port-channels in the group:
Port-channel: Po1    (Primary Aggregator)
Age of the Port-channel   = 0d:00h:00m:34s
Logical slot/port   = 1/0          Number of ports = 0
HotStandBy port = null
Port state          = Port-channel Ag-Not-Inuse
Protocol            =   LACP
Port security       = Disabled
Switch#
CF
Jon Marshall
If you want to see vlan membership then -
"sh int trunk po<x>"
although to be honest it's just as easy to look at config ie. if the "switchport trunk allowed vlan ..." command has been used that will tell which vlans are allowed across the link.
If there is no such command then all vlans are allowed by default.
Jon
Andre Neethling
Level 4
Level 4
Hi Rahmat
You can try the following commands
show run interface portchannel <x> where x is the channell group ID
or
sh interface  portchannel <x> where x is the channell group ID
