VG350 Power Requirments
smith.matthew1
Good morning.
I have been looking at the data sheet for the VG350 and notice it is rated at 720w. I assume this is the startup power. Does anyone know the running power ie the power after the unit has started and settled.
Matt Smith
Shawn Guertin
I did not use a physical power meter, but I typed the command show environment on two VG350 and thats what you might be looking for:
SYSTEM POWER
 Motherboard Components Power consumption = 110.9 WPower consumption =
 NM/SM slot 2 40.7 WPower consumption =
 NM/SM slot 4 42.0 W
 Total System Power consumption is: 193.6 W
SYSTEM POWER
 Motherboard Components Power consumption = 138.7 WPower consumption =
 NM/SM slot 2 40.3 WPower consumption =
 NM/SM slot 4 39.5 W
 Total System Power consumption is: 218.5 W
