11-25-2011 06:49 PM - edited 03-07-2019 03:36 AM
Hi everybody
How is everyone?
A virtual is established between R1 and R3
R1 and R3 both are connected via virtual link.
R1 is configured to use Md5 on virtual link while R3 is not.
I am surprised to find the link stay up even when i reset the ospf process on r3.
Is it the normal behavior ?
Below is the config:
R3 config:
router ospf 1
router-id 3.3.3.3
log-adjacency-changes
area 1 virtual-link 1.1.1.1
network 198.198.198.0 0.0.0.255 area 0
network 199.199.199.0 0.0.0.255 area 1
R1 config:
router ospf 1
router-id 1.1.1.1
area 1 virtual-link 3.3.3.3 authentication message-digest
area 1 virtual-link 3.3.3.3 message-digest-key 1 md5 zee
network 10.0.0.0 0.255.255.255 area 0
network 200.200.200.0 0.0.0.255 area 1
R3#clear ip ospf process
Reset ALL OSPF processes? [no]: y
R3#
*Mar 1 01:26:15.147: %OSPF-5-ADJCHG: Process 1, Nbr 2.2.2.2 on Serial0/0 from FULL to DOWN, Neighbor Down: Interface down or detached
R3#
*Mar 1 01:26:16.155: %OSPF-5-ADJCHG: Process 1, Nbr 2.2.2.2 on Serial0/0 from LOADING to FULL, Loading Done
R3#show ip ospf virtual-link
Virtual Link OSPF_VL1 to router 1.1.1.1 is up
Run as demand circuit
DoNotAge LSA allowed.
Transit area 1, via interface Serial0/0, Cost of using 128
Transmit Delay is 1 sec, State POINT_TO_POINT,
Timer intervals configured, Hello 10, Dead 40, Wait 40, Retransmit 5
Hello due in 00:00:08
Thanks and have a nice weekend
Solved! Go to Solution.
11-26-2011 01:55 AM
Hi Sarah,
I belive you are using GNS3. Which image are you using. I labbed it on a 7200 and can see the virtual link bounce.
r11#sh ip ospf virtual-links
Virtual Link OSPF_VL1 to router 10.1.1.1 is up
Transit area 1, via interface GigabitEthernet1/0, Cost of using 1
Hello due in 00:00:03
r11#clear ip ospf process
Reset ALL OSPF processes? [no]: yes
*Nov 26 20:42:57.655: %OSPF-5-ADJCHG: Process 1, Nbr 10.1.1.1 on GigabitEthernet1/0 from FULL to DOWN, Neighbor Down: Interface down or detached
*Nov 26 20:42:57.791: %OSPF-5-ADJCHG: Process 1, Nbr 10.1.1.1 on GigabitEthernet1/0 from LOADING to FULL, Loading Done
Virtual Link OSPF_VL1 to router 10.1.1.1 is down
Transit area 1, Cost of using 65535
Transmit Delay is 1 sec, State DOWN,
r11#
Kishore
11-26-2011 01:55 AM
Hi Sarah,
r11#
Kishore
11-26-2011 07:17 PM
Thanks Kishore
Cisco IOS Software, 2600 Software (C2691-ADVIPSERVICESK9-M), Version 12.4(15)T6, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Mon 07-Jul-08 04:30 by prod_rel_team
