Virtual Switch System (VSS) - Standby chassie interfaces do not show
jhonny.eriksson
I just configured VSS for the first time and while everything seem to have converged accordingly I seem to have issues with the standby chassis. Looking into show run I see the 2nd chassie interfaces "Gigabitethernet 2/x/y". But looking in show interfaces status, I can only see the interfaces belonging to chassie 1. Same thing when I issue show module, only chassie 1 module shows.
Same thing shows if I specify the virtual switch for each show command;
VSS-Switch#show module switch 1
Switch Number:     1   Role:   Virtual Switch Active
Mod Ports Card Type                              Model              Serial No.
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1129USTK
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD10320A5G
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD10320AAN
  4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD10270A8X
  5    5  Supervisor Engine 720 10GE (Active)    VS-S720-10G        SAL14480SCN
  6   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD10270A7L
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  001b.d5fb.a618 to 001b.d5fb.a647   2.6   12.2(14r)S5  12.2(33)SXJ  Ok
  2  0018.b9a6.ecf2 to 0018.b9a6.ed21   2.4   12.2(14r)S5  12.2(33)SXJ  Ok
  3  0019.0627.c392 to 0019.0627.c3c1   2.4   12.2(14r)S5  12.2(33)SXJ  Ok
  4  0018.19ee.5ab4 to 0018.19ee.5ae3   2.3   12.2(14r)S5  12.2(33)SXJ  Ok
  5  68ef.bd83.18a0 to 68ef.bd83.18a7   3.2   8.5(4)       12.2(33)SXJ  Ok
  6  0018.197e.189a to 0018.197e.18c9   2.3   12.2(14r)S5  12.2(33)SXJ  Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1129V1R5  3.1    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1032XGNM  2.0    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL1031X6Q9  2.0    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAD102702KV  2.0    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL14470KY2  1.1    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL14480P72  5.1    Ok
  6  Centralized Forwarding Card WS-F6700-CFC       SAL1028UJYJ  2.0    Ok
Mod  Online Diag Status
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
  6  Pass
VSS-Switch#show module switch 2
Switch Number:     2   Role:  Virtual Switch Standby
In the logg I see no traces that the modules belonging to Switch 2 has passed any diagnostics. However the interfaces are configureable?
Very grateful for help....!
Best Regards
Jhonny Eriksson
7 Replies 7
Reza Sharifi
What is the output of "sh switch virt"?
also, can you post the vss configs?
Thanks for the reply! Here it goes (show commands & config);
Show commands;
SwitchVSS#show switch virtual
Switch mode                  : Virtual Switch
Virtual switch domain number : 100
Local switch number          : 1
Local switch operational role: Virtual Switch Active
Peer switch number           : 2
Peer switch operational role : Virtual Switch Standby
SwitchVSS#show switch virtual role
Switch  Switch Status  Priority     Role    Session   ID
        Number         Oper(Conf)           Local    Remote
LOCAL    1     UP       255(255)    ACTIVE   0        0
REMOTE   2     UP       100(100)    STANDBY  5943     6769
The configuration;
Switch-1(config)# switch virtual domain 100
Switch-1(config-vs-domain)# switch 1 priority 255
Switch-1(config-vs-domain)# exit
Switch-2(config)# switch virtual domain 100
Switch-2(config-vs-domain)# switch 2 priority 100
Switch-2(config-vs-domain)# exit
Switch-1(config)# interface port-channel 1
Switch-1(config-if)# switch virtual link 1
Switch-1(config-if)# no shutdown
Switch-1(config-if)# exit
Switch-2(config)# interface port-channel 2
Switch-2(config-if)# switch virtual link 2
Switch-2(config-if)# no shutdown
Switch-2(config-if)# exit
Switch-1(config)# interface range tengigabitethernet 5/4-5
Switch-1(config-if)# channel-group 1 mode on
Switch-2(config)# interface range tengigabitethernet 5/4-5
Switch-2(config-if)# channel-group 2 mode on
U need to try below
show interface status switch (switch no) module (module no#).
By default the chassis will show the info from active switch.
In addition u r missing switch mode virtual command under the vitrual domain .
Are both switches configured in SSO mode?
Also, as the Mahmood noted: add switch mode virtual command under the vitrual domain for both switches.
I can't see any "switch mode" command in virtual domain configuration mode ? All I can set are the Switch number and priority. Of course I added the "switch convert mode virtual" to both chassis before restart.
I did it all over again and verified that both chassis were indeed configured for operating with SSO.This is a Single-SUP Dual-Chassie setup. Still no modules show under the "show module switch 2".
SwitchVSS#show int status switch 1
Port         Name               Status       Vlan       Duplex  Speed Type
Gi1/1/1                         disabled     routed       auto   auto 10/100/1000BaseT
Gi1/1/2                         disabled     routed       auto   auto 10/100/1000BaseT
Gi1/1/3                         disabled     routed       auto   auto 10/100/1000BaseT
Gi1/1/4                         disabled     routed       auto   auto 10/100/1000BaseT
Gi1/1/5                         disabled     routed       auto   auto 10/100/1000BaseT
/// Lines omitted
Gi1/6/45                        disabled     routed       auto   auto 10/100/1000BaseT
Gi1/6/46                        disabled     routed       auto   auto 10/100/1000BaseT
Gi1/6/47                        disabled     routed       auto   auto 10/100/1000BaseT
Gi1/6/48                        disabled     routed       auto   auto 10/100/1000BaseT
Po1                             notconnect   routed       auto   auto
SwitchVSS#show int status switch 2
/// No switchports is shown...
SwitchVSS#
Interesting fact is that the VSL link (Po1) shows "not connect". However, they show active;
SwitchVSS# show switch virtual link
VSL Status : UP
VSL Uptime : 13 minutes
VSL SCP Ping : Pass
VSL ICC Ping : Pass
VSL Control Link : Te1/5/5
PS: Spelling error on the configuration. This is what I added;
I managed to solve this. It showed that I recived the supervisors  with different IOS running on them. Hence only RPR mode initiated. By  copying the IOS running on the active supervisor to the standby and then  initiating a redundancy reload peer everything went up!
VSS-Switch#show module switch all
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
  6  Pass
  1   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1031WPYS
  2   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAL1321QBSG
  3   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD10320A5M
  4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD10270A6K
  5    5  Supervisor Engine 720 10GE (Hot)       VS-S720-10G        SAL13474899
  6   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD103208KC
  1  0018.b98d.4118 to 0018.b98d.4147   2.4   12.2(14r)S5  12.2(33)SXJ  Ok
  2  0025.8448.7ef0 to 0025.8448.7f1f   3.0   12.2(18r)S1  12.2(33)SXJ  Ok
  3  0019.0627.c4b2 to 0019.0627.c4e1   2.4   12.2(14r)S5  12.2(33)SXJ  Ok
  4  0018.197e.192a to 0018.197e.1959   2.3   12.2(14r)S5  12.2(33)SXJ  Ok
  5  001f.9e2a.31a0 to 001f.9e2a.31a7   3.2   8.5(4)       12.2(33)SXJ  Ok
  6  0018.b9a6.edb2 to 0018.b9a6.ede1   2.4   Unknown      Unknown      Other
  1  Centralized Forwarding Card WS-F6700-CFC       SAL1032XG42  2.0    Ok
  2  Centralized Forwarding Card WS-F6700-CFC       SAL1316NP4N  4.1    Ok
  3  Centralized Forwarding Card WS-F6700-CFC       SAL1032XFY1  2.0    Ok
  4  Centralized Forwarding Card WS-F6700-CFC       SAL1027TY1Y  2.0    Ok
  5  Policy Feature Card 3       VS-F6K-PFC3C       SAL13474A94  1.1    Ok
  5  MSFC3 Daughterboard         VS-F6K-MSFC3       SAL13463L6Z  5.0    Ok
  6  Centralized Forwarding Card WS-F6700-CFC       SAL1032XG1P  2.0    Other
  1  Pass
  2  Pass
  3  Pass
  4  Pass
  5  Pass
Wes Brown
This is bad programming on Cisco's part but the way to see just specific module interface status on the second switch in a VSS pair is the following command.
Show interface status module (1-20). This allows enough room for 2 4510 series switches with fully loaded modules.
So lets say you want to see Module 2 on the second switch. The command would be "show interface status module 12"
I think it would have been better programmed as "show interface status switch 2 module 2"
