VLAN 20 doesn't exists but it shows it does
ciscoscottc
  I have a 1711 router.  I've added vlan 20.  When I try to add fa1 to vlan 20, I get this:
lanaprouter(config-if)#swit
lanaprouter(config-if)#switchport access vlan 20
%Access VLAN 20 does not exist. Please add it to vlan database
  Here is my configuration:
Current configuration : 1303 bytes
version 12.4
hostname lanaprouter
boot-start-marker
boot-end-marker
enable secret 5 $1$4DhJ$hsErstXh6uzuIyyOlici50
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip domain name lanap
ip ssh version 2
username scott secret 5 $1$1/16$6opNCnPnhVcejILn5VzI91
interface FastEthernet0
ip address dhcp
duplex auto
speed auto
interface FastEthernet1
shutdown
ip default-gateway 192.168.1.1
no ip http server
no ip http secure-server
  However when I do sho ip int br it shows:
Async1 unassigned YES NVRAM administratively down down
FastEthernet0 192.168.1.15 YES DHCP up up
FastEthernet1 unassigned YES unset up up
FastEthernet2 unassigned YES unset administratively down down
FastEthernet3 unassigned YES unset administratively down down
FastEthernet4 unassigned YES unset administratively down down
Vlan1 unassigned YES NVRAM up down
Vlan20 192.168.2.5 YES manual up down
  And if I try to assign an address to fa1 it says it may not be configured on level 2 links.  Can someone please tell me what I'm doing wrong?  Thanks.
6 Replies 6
Hello
confg t
vlan 20
exit
sh vlan brief
res
Paul
Kind Regards
Paul
  My router doesn't seem to do some commands right.  Here's the output I get:
lanaprouter#conf t
Enter configuration commands, one per line. End with CNTL/Z.
lanaprouter(config)#vlan 20
% Invalid input detected at '^' marker.
lanaprouter(config)#vlan ?
accounting VLAN accounting configuration
  I think this might be what you're looking for:
lanaprouter#conf t
lanaprouter(config)#int vlan 20
lanaprouter(config-if)#^Z
lanaprouter#sho int vlan 20
Vlan20 is up, line protocol is down
Hardware is EtherSVI, address is 000f.349a.31de (bia 000f.349a.31de)
Internet address is 192.168.2.5/24
MTU 1500 bytes, BW 100000 Kbit, DLY 1000000 usec,
Last input never, output never, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 output errors, 1 interface resets
I try to do sh vlan brief, but once again, commands don't seem to work the same as everyone else's, here's what I get:
lanaprouter#conf t
lanaprouter(config-if)#exit
lanaprouter(config)#sh vlan brief
lanaprouter(config)#exit
lanaprouter#sho int vlan 20 brief
Any help is appreciated.
I am not sure if 1711 supports it, but If your router has "IP Pluse" image installed you maybe able to use sub-interfaces and than configure the sub-interface with dot1q and vlan 20.
interface FastEthernet1.20
encap dot1q 20
ip address x.x.x.x
HTh
Furose M
Level 3
Level 3
Please try this.
1.    At Priveleged Exec mode: type "vlan database".
2.    You should be in VLAN configuration mode. Then type "VLAN 20". The to exit Vlan mode type exit.
3.    Go ahead and type switchport access vlan 20 under interface Fa1.
This is indeed how to create a VLAN on a Cisco 1711 router. You need to add it to the vlan database. Good answer.
I get the same results.
