VLAN access Issue
paul.tim681
On Catalyst 4500 switch I configured 4 VLANS and on access switch there is command "Switchport trunk allowed vlan" ;
From any server in vlan 3 I cannot access RDP to a user PC on vlan 2  ;  but vice-versa from any PC on vlan 2 I can RDP to Server in VLAN 3
4500 configuration
vlan 2
name users
vlan 3
name server
vlan 4
name management
vlan 5
name guest
interface vlan 2
ip address 10.10.10.1 255.255.255.0
interface vlan 3
interface vlan 4
ip address 10.10.100.1 255.255.255.0
interface vlan 5
ip address 192.168.100.1 255.255.255.0
The port which connects to the Access switch is configured
switchport trunk encap dot1q
switchport mode trunk
on 2960 access switch
int gi 0/0
switchport trunk allowed vlan 2
all FastEthernet ports are configured as
switchport mode access
switchport access vlan 2
Any input how to tackle this issue.
cheers
Paul
Reza Sharifi
Can you provide the configs for vlan 3 on the 2960 switch?
If you have multiple vlans configured on the 2960 (vlan 1,2,...) then you need to allow them in your uplink or just do a
switchport mode trunk to allow all.
2960 access switch is conffigured as VTP Client mode. show vlan displays all vlan created including vlan 3.
when i configure managment vlan on access switch to manage the switch, i cannot access it as well.
Switchport trunk allowed vlan 2
4500--------------trunk---------------2960
any host behind 2960 access-switch can access all host/server in all vlan
only host in vlan2 can communicate with host behind 2960 switch other host in different vlan cannot?
how does this work "Switchport trunk allowed vlan 2"
Looking at the wording it only allows vlan2 but both direction or one direction
cheers
Paul
Hi Paul,
You need to allow the vlans you have configured on your 2960 on your trunk port. Right now you are only allowing vlan 2 and not 3 or 4.  The 2960 is a layer-2 switch only and can only have one svi configured for management.
vlan 2 is allowed both direction.
Use the following command on the trunk links.
switchport trunk allowed vlan add 3-5
If you just use the command 'switchport trunk allowed vlan x' it will get rid of all the vlans you have allowed
as of date and replace it with whatever the command is
the 'switchport trunk allowed vlan ADD" command will ADD the vlan to the list of vlans allowed on
that trunk link.
I hope they helped you better understand the two commands. And Reza is 100% correct, that should
fix your problem.
