vlan access-map match ip address problem
BAT MGL
Visitor
I am trying to create a VACL, which allows only 10.116.14.0/26 IP addresses in vlan 422, but after I configure VACL, a client with IP address 10.116.14.2/26 stops pinging its gateway 10.116.14.1/26. It was pinging the gateway before I configure VACL.
L3 switch is C3550 (c3550-ipservicesk9-mz.122-46.SE)
interface FastEthernet0/22
   switchport mode trunk
   switchport nonegotiate
interface Vlan422
   ip address 10.116.14.1 255.255.255.192
vlan access-map IP422 10
   action forward
   match ip address 28
vlan access-map IP422 20
   action drop
vlan filter IP422 vlan-list 422
access-list 28 permit 10.116.14.0 0.0.0.63
The client is connected to a C2960X (c2960x-universalk9-mz.152-6.E).
interface GigabitEthernet1/0/1
   switchport access vlan 422
   switchport mode access
   spanning-tree portfast edge
interface GigabitEthernet1/0/24
If I remove match ip address 28 from vlan access map, the client starts to ping again. I suspect that something is wrong with the access-list, but I cannot find anything wrong.
Could someone tell me what am I missing, please?
BAT
5 Replies 5
 The syntax of this acl seems weird.
Did you try something like?
Or maybe specify the origem.
access-list 28 permit ip any  10.116.14.0 0.0.0.63
I tried standard ACL, extended ACL. All the same, the client can't ping the gateway.
action forward
match ip address 128   <--- or 129
action drop
access-list 128 permit ip any 10.116.14.0 0.0.0.63
access-list 129 permit ip 10.116.14.0 0.0.0.63 any
M02@rt37
Hello @BAT MGL,
you need to modify your access-list and access-map configuration.
interface Vlan422
action drop
match ip address 28
action forward
access-list 28 deny any
--Action of access-map sequence 10 to "drop" and access-map sequence 20 to "forward". This way, traffic from the specified IP range (10.116.14.0/26) will be dropped, while other traffic will be forwarded.
Best regards
But I want traffic from 10.116.14.0/26 IPs to be forwarded, and all other traffic to be dropped. Your suggestion is exactly the opposite from what I want 🙂
access-list 128 permit ip <GW IP > 10.116.14.0 0.0.0.63
access-list 129 permit ip 10.116.14.0 0.0.0.63 <GW IP>
try this way
