Vlan Across a Layer 3 P-T-P
raun.williams
Level 3
Level 3
I'm trying to come up with a way to take a layer 2 vlan (81) that is on network A and make it available on Network C. Each network being a PtP to one another:
A-B-C. Is such a thing possible? It seems it would be some what simple to do, but not sure where to look. What I need to do is be able to stick devices from network C in vlan 80 originating on Network A and have them not know any difference? ANY help is greatly appreciated.
8 Replies 8
I'm sorry, instead of layer 3 point to point, I should have said routed point-to-point connections. How can I carry a vlan from network A to network C over the routed connections?
You can enable ip routing if you have an image supporting it.
Then you can use a routing protocol between a,b,c.
Raun,
If I understand you correctly, then you want VLAN81 and it's associated IP subnet from site A to be present at site C, right?
If this is correct, then you should be able to use pseudowire with l2tpv3 on your routers a and c to establish what you want.
Yup, you got it. That's what I need. Is pseudowire available on 3750's and 6509's? We don't use true routers on site to site as it's all a private network. What about vlan bridging?
Hello Raun,
in your case change the link in a L2 trunk on both sides with previous IP subnet used on point to point link associated to a new vlan.
Add vlan 81 and eventually other vlans on the trunk.
use
switchport mode trunk
switchport nonegotiate
switchport trunk allowed vlan 81,X
where X is the new vlan for L3 traffic, 81 the vlan to be extended
to avoid problems with different VTP domains
L2TPv3 may be supported on 6509 but it shouldn't be on 3750
Edit:
note that Lucien had suggested this on its first post, providing details about devices involved help to make the best choice.
A L2 trunk between two lan switches is easy and efficient.
Hope to help
Giuseppe
Pls. see this link for more on L2TPv3:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t2/feature/guide/gtl2tpv3.html
Edit: Did not notice the replies regarding this being switches and not routers. I fully agree with Giuseppe's edit. There's no need to try to do fancy stuff when the obvious solution with switches is to use VLAN and trunking.
I suppose I consider this doing fancy stuff myself as we're talking about links between major campuses for a hospital system. I was looking for an add-on config versus's a rebuild, something to go along with our current configuration.
