Vlan and Trunk
erdosain99
Hi. I have a Cisco 2901 (2 onboard GE) and 4 interfaces ethernet module.
i want to know if it is possible do
four vlan: 1,2,3,4
and one trunk for that vlans....? (the trunk will be the wan of my config).
Can someone give my a hand??
This is my wan
"interface GigabitEthernet0/0
ip address 192.168.1.11 255.255.255.0"
and this my config:
Current configuration : 3789 bytes
version 15.3
service password-encryption
hostname Rxxxx
boot-start-marker
boot-end-marker
enable password 7 131512020A5F5C7D78957A60242309
aaa new-model
aaa session-id common
ip cef
ip dhcp excluded-address 10.0.158.1 10.0.158.128
ip dhcp excluded-address 192.168.9.1 192.168.9.128
ip dhcp pool Red9
network 192.168.9.0 255.255.255.0
default-router 192.168.9.1
dns-server 192.168.1.1
lease 0 2
ip dhcp pool Red158
network 10.0.158.0 255.255.255.0
default-router 10.0.158.1
lease 0 2
ip domain name xxxx
ip name-server 192.168.1.1
no ipv6 cef
voice-card 0
license udi pid CISCO2901/K9 sn FTX180581WJ
hw-module pvdm 0/0
username admin secret 4 18ENFd/4nHi1uCHjK8Ai/fLcHh.HWwQWGpc4D7sdqs.
redundancy
ip ssh time-out 90
ip ssh authentication-retries 2
ip ssh version 2
class-map match-all Red9
match access-group 169
class-map match-all Red158
match access-group 158
policy-map AnchoBanda
class Red9
bandwidth 1500
class Red158
bandwidth 500
interface Embedded-Service-Engine0/0
no ip address
shutdown
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
service-policy output AnchoBanda
interface GigabitEthernet0/1
ip address 192.168.9.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1/0
switchport access vlan 158
no ip address
interface GigabitEthernet0/1/1
no ip address
interface GigabitEthernet0/1/2
no ip address
interface GigabitEthernet0/1/3
no ip address
interface Vlan1
no ip address
interface Vlan158
ip address 10.0.158.1 255.255.255.0
ip nat inside
ip default-gateway 192.168.1.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 109 interface GigabitEthernet0/0 overload
ip nat inside source list 158 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.1
access-list 109 remark ==Red9 con acceso telefonico y bloqueo a red 1==
access-list 109 permit udp 192.168.9.0 0.0.0.255 192.168.1.0 0.0.0.255 range 10000 20000
access-list 109 permit udp 192.168.9.0 0.0.0.255 192.168.1.0 0.0.0.255 range 5060 5065
access-list 109 deny ip 192.168.9.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 109 permit ip 192.168.9.0 0.0.0.255 any
access-list 158 remark ==Red 158 con acceso telefC3nico y bloqueo a red 1==
access-list 158 permit udp 10.0.158.0 0.0.0.255 192.168.1.0 0.0.0.255 range 10000 20000
access-list 158 permit udp 10.0.158.0 0.0.0.255 192.168.1.0 0.0.0.255 range 5060 5065
access-list 158 deny ip 10.0.158.0 0.0.0.255 192.168.1.0 0.0.0.255
access-list 158 permit ip 10.0.158.0 0.0.0.255 any
access-list 168 remark ==Ancho de banda lan 158==
access-list 168 permit ip 10.0.158.0 0.0.0.255 any
access-list 169 remark ==Ancho de banda Lan 9==
access-list 169 permit ip 192.168.9.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
gatekeeper
shutdown
line con 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password 7 0831495E084A5D40405A5E573B2A3E
transport input ssh
scheduler allocate 20000 1000
end
Cisco CISCO2901/K9
6 Replies 6
mikeleebrla
I'm not 100% sure i understand your question completely, but if you are asking how to trunk the GIG0/0  interface on your router into VLANs 1,2,3, and 4, below is the config.
interface GigabitEthernet0/0.1
 description *** VLAN 1 ***
 encapsulation dot1Q 1 native
 ip address x.x.x.x  255.255.255.0
interface GigabitEthernet0/0.2
description *** VLAN 2 ***
 encapsulation dot1Q 2
 ip address y.y.y.y 255.255.255.0
interface GigabitEthernet0/0.3
 description **** VLAN 3****
 encapsulation dot1Q 3
 ip address a.a.a.a 255.255.255.0
interface GigabitEthernet0/0.4
 description ***VLAN 4***
 encapsulation dot1Q 4
 ip address b.b.b.b 255.255.255.0
Yes, sorry, i dont speak well english....
That's what i want. But i have declare also "ip nat outside"?? in all the sub interfaces??
And, for example, if i have a server in 192.168.9.250 and i want to have accesible that server from internet in port 9000......... the syntax will be???
The wan of that cisco, like i say is 192.168.1.11 (its not the border router.......)
you just need to add the "ip nat outside" to whichever subinterface has the IP that you are trying to NAT, not all of them.  Do the NAT/PAT commands just how you would normally as if there aren't any sub-interfaces or a trunk. See below:
R1(config)#ip nat inside source static tcp 192.168.9.250 9000 Public-IP-Here 9000
R1(config)#interface GigabitEthernet0/0.1  ----- this is your outside interface
R1(config-if)#ip nat outside
R1(config-if)#interface GigabitEthernet0/1  ----this is your inside interface
R1(config-if)#ip nat inside
R1(config-if)#exit
R1(config)#exit
AJ Acevedo
Be careful with posting Cisco configurations that include your enable password hash. It is not secure and simply using an online Cisco password cracker can reveal your actual decrypted password.
Thanks! but i change some letters  and numbers :-)
ah! Smart move!
