VLAn and VTP configuration..
iceman0813
Hi can you please check if my configuration below is correct or do you have any suggestion?
I have 3550 and 1 2960, the 2960 will connect on 3550 using VTP and with VLAn configuration. please check below my config.
3550 configuration
config t
vtp domain cisco.com
vtp passord cisco
vtp mode server
config t
int vlan 2
ip address 153.117.183.1 255.255.255.240
no shut
end
config t
int fa0/48
switch port trunk encapsulation dot1q switchport mode trunk
exit
2960 configuration
config t
vtp passord cisco
vtp mode client
config t
int vlan 2
ip address 153.117.183.2 255.255.255.240
no shut
end
config t
vlan 2
name WIP_clients
exit
config t
int fa0/3
switchport mode access
witchport access vlan2
end
int fa0/4
switchport access vlan2
end
int fa0/5
end
int fa0/6
end
config t
int fa0/1
end
glen.grant
Make sure you make the layer 2 bvlan on the 3550 also , besides that it looks like it should work . Myself I would make the links with this command and let the switches negotiate the trunks.
switchport mode dynamic desirable on the connecting links.
what do you mean? is thay correct to use swithcport mode trunk on both 3550 and 2960 switch?
thanks again
Yes you can use that also or the way I stated , which is "switchport mode dynamic desirable" instead of switchport mode trunk. Either way will work .
