Vlan Best Practice
dcanady55
Level 6
Level 6
I am wondering about the following scenario and if it falls under a best practice. Two locations and each location is identical in terms of equipment and purpose. Let's say location A had a vlan 100 with 172.15.5.0/24 would location B best be setup with Vlan 100 and 172.15.6.0/24 or would most use a different vlan like 101? I'm using the octets to classify the location but curious if most would also change the vlan 100. I'm inclined to keep it at 100 and just change the IP so its more consistent but from a security stand point wasn't sure if that's best.
thanks in advance!
2 Accepted Solutions
Reza Sharifi
You usually want one vlan with the corresponding subnet and if possible match the 3rd octed with the VLAN id. This way it is easy to remember that  subnet100 is vlan 100 and subnet 101 is vlan 101, etc...
Assuming 2 vlans per location
Location-A VLAN 100 subnet 172.16.100.0/24
Location-A VLAN 101 subnet 172.16.101.0/24
Location-B VLAN 102 subnet 172.16.102.0/24
Location-B VLAN 103 subnet 172.16.103.0/24
Joseph W. Doherty
I don't recall either approach being a "best practice".
In cases where it's possible VLANs might need to be merged on same switch(es), of course, your best approach it to insure each has a unique VLAN so this could be done.
In cases where you'll never combine such VLANs on the same switch, perhaps using the same VLAN number for a functional purpose might be the better approach.
As my last job, where we had 5,000 Enterprise network devices, spread across quite a few sites, of varying sizes (i.e. from just a couple of hosts to thousands of hosts at a site), we used the latter approach.  This because, network IP assignments come and go and it can be difficult to always have VLAN number match part of the network IP match in some way.  However, you can usually, at least, use the same VLAN number for the same "function" at different sites.
6 Replies 6
Reza Sharifi
I really appreciate you taking the time to give your input thanks.
Joseph W. Doherty
Thanks Joseph,
I think both responses are valid but do feel keeping the vlan the same across multiple sites makes the most sense to me. I don't think I mentioned it but these Vlans would be for the same thing at those sites (vlan100=voice, vlan200=data..) which further makes me think keeping the numbers the same would be best. I just wasn't sure from a security stand point if that was frowned upon.
thanks,
If the purpose is going to be the same at each site then absolutely feel free to use the same vlan ID as long as the sites are separated by L3 you will be fine.
I have never heard a reason why it would be a security issue as such.
Jon
Like Jon, I'm unaware of any specific security issue using the same VLAN number, for functional groups, on different switches.
BTW, both approaches are fine, also perhaps not using either approach too, but I might add, it might be more "work" to try to maintain some part of an IP address to match a VLAN number and/or functional purpose - think of the impact of various sized networks.  (I.e. what Reza showed using /24s, and their third octet, would be about the best possible case.)
Also, BTW, if something is actually a "best practice", consider whether it's really such for you too.  If something is truly a best practice, that doesn't mean you have to follow that practice, but don't just contravene it without careful consideration and good reason.
