VLAN Cisco and HP
Wajma_2
I would like to seek help on the following situation:
We have remote site with couple of HP switches one uplinked to another and then uplinked to a Cisco 3560 switch. The default vlan in remote site is using IP address 10.20.60.x (VLAN REMOTE ). The Cisco switch routes the VLAN information to VLAN WIRELESS connected on another port of the switch (IP address 10.20.16.X). On the HQ side we have another cisco 3560 switch that has VLAN WIRELESS and VLAN NETWORK (10.10.0.X).
My question is : Is it possible to create another VLAN at the HP2650 switch named VLAN SPECIAL and be able to carry this vlan through the HP4204 and both Cisco 3560 switches so that this new VLAN have access to the main network and the Internet and What configuration do I need to change.
Please see attached network diagram.
Thank you for looking into this.
WO
The following are the configuration on Cisco 3560 on the Remote site
interface GigabitEthernet0/3
switchport access vlan REMOTE
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/4
description Wireless_To_HQ
switchport trunk native vlan WIRELESS
switchport trunk allowed vlan WIRELESS
switchport mode trunk
interface VlanWIRELESS
ip address 10.20.16.8 255.255.255.0
interface VlanREMOTE
ip address 10.20.60.1 255.255.255.0
ip helper-address 10.10.0.50
ip helper-address 10.10.0.40
ip classless
ip route 0.0.0.0 0.0.0.0 10.20.16.3 150 (this is forwarding to the cisco 3560 at the HQ)
The following are the configuration of cisco 3560 at HQ
interface GigabitEthernet0/1
description HQ
switchport trunk allowed vlan NETWORK,WIRELESS
interface GigabitEthernet0/2
description wireless at HQ
interface Vlan NETWORK
ip address 10.10.0.2 255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 10.10.0.1
ldardon
In Cisco switch you have add the VLAN and trunk the VLAN Special.
switchport trunk allowed vlan WIRELESS, VLAN SPECIAL.
Use the following commands in HP switch this is just a example
vlan 125
name "VLAN125"
untagged 1-24
ip address 10.50.0.6 255.255.254.0
tagged 26
exit
