vlan doesn't work
mlatterell
Hi there. I have what is hopefully a very easy/newbie question. I work for a nonprofit that received a WS-C2960S-24TS-L as a donation. We want to create a VLAN on a single port that is connected to a 5-port switch to segment the computers used by our participants from our office computers.
I believe I followed the steps correctly to telnet to the device, create the VLAN and then assign a port to the VLAN. However when I plug the switch (or even just a single computer) into the jack connected to that port the computer is unable to resolve an IP address (Windows 7 reports that it won't connect tho my location network or the Internet). I have tried creating the VLAN on a different port, tried different cables but the same results. The VLAN port on the Cisco lights up green when I connect to it, but the computer/s on the receiving end don't get a conection. Am I missing a command I should issue once the VLAN is created and the port is assigned? It seems like it should be a straight-forward process but it just doesn't seem to work.
Thanks in advance for any suggestions.
glen.grant
   To add a new vlan just do this.   How is the the 2960 hooked to the rest of your network and where is your dhcp server located?
conf t
vlan X
exit
interface g0/X
switchport
switchport mode access
switchport access vlan X
Martin Carr
Level 4
Level 4
As said, you need to elaborate more on your topology.
The reason it's not working is as you have just simply placed it within a VLAN, this means it is isolated and therefore cannot communicate with anything else!
Martin
vishal vyas
creating vlan provide you layer-2 connectivity thats why your port on switch turns green, but in order to connect with network you also need layer-3 connectivity by assigning an ip address.
example:
vlan 10
exit
interface vlan 10
ip address 10.1.1.1 255.255.255.0
no shut
interface g0/1
switchport access vlan 10
no shut
