Vlan Help
paul dungey
Level 3
Level 3
Good afternoon,
Below is a copy of the switch VLan information I've erased the Vlan.dat file from flash, when i reboot the switch and run the show vlan
I can still see the following, how can i delete these entries
2    vlanTraining                     active
3    vlanTraining2                    active
Switch#show vlan
VLAN Name                             Status    Ports
1    default                          active    Fa0/1, Fa0/2, Fa0/3, Fa0/4,
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8,
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12,
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/16,
                                                Fa0/17, Fa0/18, Fa0/19, Fa0/20,
                                                Fa0/21, Fa0/22, Fa0/23, Fa0/24,
                                                Fa0/25, Fa0/26, Fa0/27, Fa0/28,
                                                Fa0/29, Fa0/30, Fa0/31, Fa0/32,
                                                Fa0/33, Fa0/34, Fa0/35, Fa0/36,
                                                Fa0/37, Fa0/38, Fa0/39, Fa0/40,
                                                Fa0/41, Fa0/42, Fa0/43, Fa0/44,
                                                Fa0/45, Fa0/46, Fa0/47, Fa0/48,
                                                Gi0/1, Gi0/2
1002 fddi-default                     active
1003 trcrf-default                    active
1004 fddinet-default                  active
1005 trbrf-default                    active
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
2    enet  100002     1500  -      -      -        -    -        0      0
3    enet  100003     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 trcrf 101003     4472  1005   3276   -        -    srb      0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trbrf 101005     4472  -      -      15       ibm  -        0      0
VLAN AREHops STEHops Backup CRF
1003 7       7       off
Switch#
Paul
Sandeep Choudhary
HI
try to use this command ...
Switch(config)# no vlan X
and the show the ouput with sh vlan command:
Please rate if it helps.
Sandeep Choudhary
HI
HI Sandeep,
Thank you for your support i've accessed  the Vlan database and run the command you gave above,
fantastic it's worked a treat and remove the vlan name.
thanks
Paul
