VLAN HELP
cozyk1515
WAN, Routing and Switching: VLAN AND STRIPPING- HELP
Posted by: cozyk1515 - Senior Network Admin, PrimeLink - Jun 20, 2007, 8:31am PST
Interface GigabitEthernet1/46- 1/48 are fiber points coming in off my Fiber equipment.
INT GIG1/1- 1/4 are going back to my Layer 3 Swtich. The fiber company wants me to give each customer its own VLAN - I know what to do for the Fiber ports (1/46-1/48 is just keep adding Addtional Vlans IE: switchport trunk allowed vlan 84,85), But I don't want to use any more then port 1-4 back to my Layer 3)
As you see I have 1 Vlan Assgined to each port back to my Switch.- How do I change that?
show run
Building configuration...
Current configuration : 3644 bytes
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
service compress-config
hostname AllopticSwitch
boot-start-marker
boot-end-marker
no aaa new-model
ip subnet-zero
vtp domain ''
vtp mode transparent
--More-- !
power redundancy-mode redundant
no file verify auto
spanning-tree mode pvst
vlan access-map 64 74
action forward
vlan access-map 84 85
action forward
vlan internal allocation policy ascending
vlan 64-65,74-75,84-85
interface GigabitEthernet1/1
description
switchport access vlan 64
switchport mode access
--interface GigabitEthernet1/2
description
interface GigabitEthernet1/3
description
switchport access vlan 74
interface GigabitEthernet1/4
description
interface GigabitEthernet1/5
description
switchport access vlan 84
interface GigabitEthernet1/6
description
interface GigabitEthernet1/7
interface GigabitEthernet1/8
interface GigabitEthernet1/9
interface GigabitEthernet1/10
interface GigabitEthernet1/11
interface GigabitEthernet1/44
interface GigabitEthernet1/45
description Alloptics-1
switchport trunk allowed vlan 64
switchport mode trunk
interface GigabitEthernet1/46
description All
interface GigabitEthernet1/47
description All
switchport trunk allowed vlan 74
interface GigabitEthernet1/48
description City
interface Vlan1
ip address 192.168.25.1 255.255.255.0
interface Vlan64
description All-1
ip address 192.168.26.1 255.255.255.0
interface Vlan65
description All-2
ip address 192.168.27.1 255.255.255.0
interface Vlan74
interface Vlan75
interface Vlan84
description CityPlattsburgh
ip address 192.168.28.1 255.255.255.0
shutdown
interface Vlan100
no ip address
interface Vlan101
no ip address
shutdown
interface Vlan2000
no ip address
shutdown
interface Vlan2500
description OFFICETEST
no ip address
shutdown
ip http server
no ip http secure-server
--More--
thomas.chen
Level 6
Level 6
A VLAN is a group of end stations with a common set of requirements, independent of physical location. VLANs have the same attributes as a physical LAN but allow you to group end stations even if they are not located physically on the same LAN segment.
VLANs are usually associated with IP subnetworks. For example, all the end stations in a particular IP subnet belong to the same VLAN. Traffic between VLANs must be routed. LAN port VLAN membership is assigned manually on an port-by-port basis
http://cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094c52.shtml
Jon Marshall
Not sure i fully understand. If you only want to use ports gi1/1 - 1/4 and no more but there are more customer vlans than 4 then you could make one of the gigbait connections a trunk and carry aall vlans down it ?
Have i misunderstood ?
Jon
