09-17-2015 11:19 AM - edited 03-08-2019 01:50 AM
09-17-2015 11:28 AM
Hi 2811 and other routers can actually come with layer 2 cards installed so even though its a router by platform there is a switching card module installed giving you basic switching functions , obviously they cost extra , these ports operate same as any other layer 2 port in terms of configuration
example module is hwic-4esw
09-17-2015 11:31 AM
Have never used packet tracer and no sure, but if you see a regular Cisco router with vlan database, most likely that router has some sort of Ether-switch blade(4 ports, 8 ports or 16 ports) installed. See below. This way the router can operate as both a switch and a router and so you don't have to purchase 2 different devices.
http://www.cisco.com/c/en/us/products/collateral/interfaces-modules/high-speed-wan-interface-cards/product_data_sheet0900aecd8016bf0b.html
09-20-2015 04:38 PM
Yes, you can create a vlan and put a few switch ports in it and the router route for the vlan interface. Its just like a small layer-2 switch connected to the router but in this case its a module that gets inserted into the router.
09-17-2015 11:28 AM
09-20-2015 11:21 AM
Hi Reza, Mark,
Thanks and sorry for the late reply.
Then in that case, for those routers with switch modules -> can the router route between the connected routes and the vlan interface ?
Noob
09-20-2015 04:38 PM
09-17-2015 11:31 AM
