Vlan in Err-Disabled State
RJRodriguez
Hello Everyone,
I ran into an issue recently. I am creating some new vlans on Nexus switches ( I have limited expeerinece with NXOs) and after I trunked all the vlans I noticed the new vlans I created were in an err-disabled on trunk ( See Attachemtn). I have applied these on Catalyst switches as well and do not have this issue, am I missing somewhere I could not have entered the Vlans appropriately?
Thank you in advance...
interface port-channel100
switchport mode trunk
spanning-tree port type network
vpc peer-link
VPC peer- link the connection between the 2 switches.
So, it appears that the above Portchannel is your VPc peer-link. As long as you have "switchport mode trunk" on both switches, you should be good to go, and no need to add any individual vlans to VPC Peer-link. Make sure the same exact config exists on both switches.
If you are still having issues, post the output of "sh vpc" and "sh vpc details" from both switches.
6 Replies 6
balaji.bandi
If this is vPC you need to allow those VLAN in vPC Link,  also check any spanning tree loops for that VLAN ?
check the logs on nexus switches
BB
Ok, I went back in and checked VPC links and I saw that they are missing the new Vlans I created, so I see VPC links and then something called a VPC Peer-Link, what is the proper way and procedure for adding the new vlans? I have not added this before just want to be sure I dont bring anything down in production.
vpc peer-link
description MasSo-Lvl2-IDM
vpc 10
vpc peer-link
vpc peer link between nexus, that should work for all the VLAN allowed in the Trunk.
vpc 10
is this connected to downlinks to other switches ?
Do you need all the VLAN to pass to downlink switches ?
have you created VLAN on the new switch ?
where is that output you took from ? from nexus? what is the output from downside switches ?
BB
Hello
Can you post the output from:
sh vpc
sh vpc conisistancy-paremeters  global
sh spanning-tree tree vlan 871
Kind Regards
Paul
