09-04-2015 10:41 AM - edited 03-08-2019 01:39 AM
Hi I notice one vlan interface is administrator shutdown. When I issued no shutdown, it has not any effect on this. What reason can cause it ? Please see it below. Thank you.
C7009-01# sh run int vlan 100
interface Vlan100
no ip redirects
ip address 172.33.10.2/24
ip router eigrp 100
ip passive-interface eigrp 100
hsrp version 2
hsrp 100
authentication xxx
preempt
priority 110
C7009-02(config-if)# sh int status | i Vlan100
Vlan100 Core Network MGMT down routed auto auto --
C7009-02(config-if)#sh ip int bri
Vlan100 172.33.10.2 protocol-down/link-down/a
09-04-2015 11:10 AM
Is there at least one device in VLAN 100 that is 'up,up'? How about a trunk port that carries that VLAN?
09-08-2015 11:06 AM
Thank you for your reply. The vlan 100 used to work before. but we just found its hsrp ip address disappear. When I tried to add the ip address, I could not add it because the error message said the ip address is used by another vlan50. When I checked the vlan 50, vlan50 does not have the same ip address with vlan 100. It is strange.
Since we cannot add the ip address to vlan100, we use another ip address for the vlan. Though I can add the ip address, the vlan100 is administrative down and cannot be up even if we issue no shutdown. Later we added the ip address in another device, now all can work well. but we still do not know what was wrong with that.
09-04-2015 11:38 AM
What does show interface vlan 100 show? If an interface is not operational there's usually a reason given on the first line indicating the error. For example:
n7k-1# sh int vlan 99 Vlan99 is down (VLAN does not exist), line protocol is down, autostate enabled [snip]
09-04-2015 05:28 PM
Showipospf,
As updated in other discussion there are only 2 possibilities:0
1- vlan @ layer 2 is not created.
2- Atleast one interface must be active(up/up state) for that particular vlan.
Example:
conf t
vlan 100
int f0/0 --- connecting to my server and in up state.
no shut
int vlan 100
ip address x.x.x.x x.x.x.x
no shut
show int vlan 100
up up.
Inayath
