Vlan Interface down and won't come up
eric_stewart
Community Member
I have a Nexus 5548 and I created a vlan 1211 and then a interface vlan 1211.  When the interface was created the it was named, given an IP address and a no shutdown command.  When I do a show interface vlan 1211 I get Vlan1211 is down (VLAN is down), line protocol is down.  I thought that I may need to have an active Ethernet port untagged in the VLAN so I did that with switchport access vlan 1211 on an test active Ethernet port.  The results are the same.
I have done this with many other VLANs but for whatever reason this one is giving me problems.  Does anyone have any ideas?
Eric
2 Accepted Solutions
stkiss
Hi Eric,
Its important to note that Nexus 5548 run NX-OS not IOS. Have You enabled the SVI feature with the "feature interface-vlan" command?
http://docwiki.cisco.com/wiki/Cisco_NX-OS/IOS_Interface_Comparison
briboyd
Hi Eric,
When you created other VLAN's on this switch, did you assign IP addresses to them? Like Steve said, without the "feature interface-vlan" you cannot configure an SVI.
- Brian
stkiss
Hi Eric,
briboyd
Hi Eric,
- Brian
