VLAN Interface on layer 2 switch
Rem Markov
Level 5
Level 5
Hey ! So I have configured an eve-ng lab.
I have a cloud which what connects me to the bridge (My network).
To the bridge I have connected a router and a switch (Cisco IOL L3 and L2).
My router automatically received an IP address.
On the switch I have configured Vlan 10 interface with a static IP address of the network and added the default gateway as the router as they both connected to the same router.
However I can't ping out or in the switch. I have tried configuring the VLAN10 on the e0/0 (the port that connects to to the cloud) and still nothing.
Help please ?
Actually I solved it, I need to put on the interface I want to work, switchport mode access , and then switchport vlan <Vlan-id of the vlan interface I want>
There problem was is that i set it as trunk instead of access.
Rem Markov
Level 5
Level 5
 The configuration on the port on the switch
Martin L
can't really see anything; picture too small; copy and paste your configs directly from cli window here; and write topology u have , et. Cloud > IOL switch > IOL rotuer ?
Note: using Cisco IOL L3 and L2 outside of CML may not work and it is illegal to do so !
Regards, ML
**Please Rate All Helpful Responses **
