VLAN INTERFACE SHOWING SHUTDOWN
Arif Rafi
  Please note that I have created a new VLAN in 4507 and configured in HSRP. B
 The newly created VLAN interface (vlan 16) is in shutdown. All other VLAN created earlier are up.
CORE 1
vlan 16
name IDF_16
interface Vlan16
ip address 10.0.16.2 255.255.255.0
standby 16 ip 10.0.16.1
standby 16 priority 150
CORE 2
vlan 16
name IDF_16
interface Vlan16
ip address 10.0.16.3 255.255.255.0
standby 16 preempt
BAS_CCTV_CORE1#sh ip int brief
Vlan15 10.0.15.2 YES NVRAM up up
Vlan16 10.0.16.2 YES manual down down
Vlan20 10.0.20.2 YES NVRAM up up
     vlan 16
VLAN must be allow in trunk and the trunk must be UP
VLAN must add to SW via
vlan x <<- add this command
7 Replies 7
M02@rt37
Hello @Arif Rafi,
Does the VLAN 16 member of an Active Trunk port ?
Best regards
 I have configured the trunk port on the interface gigabitEthernet2/45 - but not active.
AMR
 @Arif Rafi
like @MHM Cisco World has just said, does the trunk port UP ?
Thanks.
Best regards
Trunk port is not up - only configured the port.
AMR
@Arif Rafi, then we find the problem!
happy for you! have a nice day.
Best regards
VLAN allowed in trunk port gigabitEthernet2/45. But it is not up. Uplink fibre  is not connected to the access switch.
Is there any way to check the interface is OK. ( I tried to ping from core switch itself to the new SVI - but not pinging.
AMR
