VLAN is flapping
BilalButt62333
Level 3
Level 3
%SW_MATM-4-MACFLAP_NOTIF: Host c84f.86fc.0004 in VLAN 10 is flapping between port Gi1/0/28 and port Te1/1/1
%SW_MATM-4-MACFLAP_NOTIF: Host c84f.86fc.0004 in VLAN 1 is flapping between port Te1/1/1 and port Gi1/0/47
what could be the reason for this, also there was a loop in my network one switch was connected twice with a second switch, could this be the reason if not then what mitigation or how to resolve this
8 Replies 8
Mark Elsen
 - If there is an accidental loop  then proper STP configurations should prevent a network meltdown, and blocking of involved ports immediately . here you find info about the mac address : https://macaddress.io/mac-address-lookup/A9RzlePm56 , not all observed mac address flapping events are related to network problems. Sometimes clustering solutions of hosts based on a mac address can lead to those messages too, or if wireless clients are hopping between access points (e.g)  ,
 M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
are there any Wireless in your network ?
yes there are wireless , the mac address that i mentioned above i think it's firewall mac address
firewall mac address that not good
are you run ASA HA ??
if yes then check the split brain FW, meaning both FW is active status
there are two firewalls in HA mode but not active-active, it's active-passive
you may say it's sophos
you config it as active-passive but it work as active-active this why the MAC address is flapping between two FW.
f you run ASA
show failover <<- check the status
balaji.bandi
also there was a loop in my network one switch was connected twice with a second switch,   - need you shed more information this, is this STP blocking ports ?
BB
Hello
If the mac address related to a vip address of say a  FHRP group (hsrp/vrrp...) then its possible what you see caused by both devices in the FHRP group  going into a active/active state, if so id check the physical connection between the two devices,
Kind Regards
Paul
