vlan issue
csco11257494
Community Member
I am having an issue two diff switches both running on 3 diff vlans and both are connected together. e.g vlan 10, 20 and 30
this 3 vlans are configured on the two switches that are connected to each other and could ping each vlans having configured the ports of the
two switches connected to trunk and having all ports in each vlan connectint to a pc to be in access but those pcs canot ping other vlans the could only ping them selfs even the switch could not ping the PC IP succesfully.
thank you would appreciate any help
22 Replies 22
Gregory Snipes
Level 11
Level 11
Please post up scrubbed configs for these devices. This will be a much easier way to determine what any issues with these devices are.
FOR SW A
spanning-tree mode pvst
vlan internal allocation policy ascending
interface FastEthernet1/0/1
switchport mode access
interface FastEthernet1/0/2
switchport access vlan 105
interface FastEthernet1/0/3
interface FastEthernet1/0/4
interface FastEthernet1/0/5
switchport access vlan 120
interface FastEthernet1/0/6
interface FastEthernet1/0/7
interface FastEthernet1/0/8
interface FastEthernet1/0/9
interface FastEthernet1/0/10
interface FastEthernet1/0/11
switchport access vlan 250
interface FastEthernet1/0/12
interface FastEthernet1/0/13
interface FastEthernet1/0/14
interface FastEthernet1/0/15
interface FastEthernet1/0/16
interface FastEthernet1/0/17
interface FastEthernet1/0/18
interface FastEthernet1/0/19
interface FastEthernet1/0/20
interface FastEthernet1/0/21
interface FastEthernet1/0/22
interface FastEthernet1/0/23
interface FastEthernet1/0/24
interface GigabitEthernet1/0/1
description link to AGGRSW2
switchport mode trunk
interface GigabitEthernet1/0/2
interface Vlan1
no ip address
interface Vlan105
ip address 192.168.1.1 255.255.255.224
interface Vlan120
ip address 192.168.1.33 255.255.255.224
interface Vlan250
ip address 192.168.1.65 255.255.255.224
ip classless
ip http server
ip http secure-server
FOR  SW B
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
description link to AGGRSW1
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface Vlan1
no ip address
interface Vlan105
ip address 192.168.1.2 255.255.255.224
interface Vlan120
ip address 192.168.1.34 255.255.255.224
interface Vlan250
ip address 192.168.1.66 255.255.255.224
   PCs config in vlan 105
ip add 192.168.1.10, S/M:255.255.255.224, D.G:192.168.1.1
PCs config in vlan 120
IP add 192.168.1.34, S/M:255.255.255.224 D.G 192.168.1.32
PC in VLAN 120 has a duplicate IP to one of the switches.
I belive you want to change the IP on the second switch to:
interface Vlan120
ip address 192.168.1.32 255.255.255.224
This is a fairly simple config and I do not see any issues with it assuming that they are properly connected together port g1/0/1 to port g1/0/25.
Things to check:
1. Do the vlans exist in both switches "Sh VLAN"
2. Is IP routing enabled, just put "IP routing" into each one for good measure
3. Check the client IP configurations
4. Do a "Sh CDP nei" just to verify layer 2
5. Ensure the hosts are connected to the correct ports
all seems to be fine i have checked all you said but i cant just figure out why vlan 105 is not pinging vlan 120
AGGRSW2#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
AGGRSW1          Gig 1/0/25        137             R S I  WS-C3750V Gig 1/0/1
AGGRSW2#
VLAN Name                             Status    Ports
1    default                          active    Gi1/0/26, Gi1/0/27, Gi1/0/28
105  uservlan                         active    Gi1/0/1, Gi1/0/2, Gi1/0/3
                                                Gi1/0/4, Gi1/0/5, Gi1/0/6
                                                Gi1/0/7, Gi1/0/8, Gi1/0/9
                                                Gi1/0/10
120  facility                         active    Gi1/0/11, Gi1/0/12, Gi1/0/13
                                                Gi1/0/14, Gi1/0/15
150  VLAN0150                         active
250  IASsecurity                      active    Gi1/0/16, Gi1/0/17, Gi1/0/18
                                                Gi1/0/19, Gi1/0/20, Gi1/0/21
                                                Gi1/0/22, Gi1/0/23, Gi1/0/24
1002 fddi-default                     act/unsup
1003 token-ring-default               act/unsup
1004 fddinet-default                  act/unsup
1005 trnet-default                    act/unsup
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
1    enet  100001     1500  -      -      -        -    -        0      0
105  enet  100105     1500  -      -      -        -    -        0      0
120  enet  100120     1500  -      -      -        -    -        0      0
150  enet  100150     1500  -      -      -        -    -        0      0
250  enet  100250     1500  -      -      -        -    -        0      0
1002 fddi  101002     1500  -      -      -        -    -        0      0
1003 tr    101003     1500  -      -      -        -    -        0      0
1004 fdnet 101004     1500  -      -      -        ieee -        0      0
1005 trnet 101005     1500  -      -      -        ibm  -        0      0
^Please see my reply to your client configs.^
sorry the ipp add is 192.168.1.39 (not .34) it was a mistake
The gateway is pointed at .32 and there is no .32. You will either need to change the switch IP to .32 or point your gateway at .34.
this is it the ip is 192.168.1.39 255.255.255.224 gateway:192.168.1.34 this is the right config
If you put both clients in the same VLAN/subnet can they ping each other?
will try that
they cant ping each other even in the same vlan
