Vlan issue
smothuku
Level 7
Level 7
Hi All,
I am facing problem with vlan's.Setup is as follows.
2950 switch (f0/3)-- (f0/0.14)R1 (s0/0/0:0)--s0/0/0:0 R2 router.
R1 and R2 are 2811 routers.
The config is as follows.
2950 switch:
nterface FastEthernet0/1
switchport access vlan 12
switchport mode access
interface FastEthernet0/2
interface FastEthernet0/3
switchport access vlan 14
interface Vlan11
ip address 10.105.40.11 255.255.255.0
no ip route-cache
ip default-gateway 10.105.40.2
R1 router:
interface FastEthernet0/0
no ip address
duplex full
speed 100
interface FastEthernet0/0.11
encapsulation dot1Q 11 native
ip address 10.105.40.2 255.255.255.0
no snmp trap link-status
standby 1 ip 10.105.40.1
standby 1 priority 105
standby 1 preempt
interface FastEthernet0/0.12
encapsulation dot1Q 12
ip address 10.105.41.2 255.255.255.128
standby 2 ip 10.105.41.1
standby 2 priority 105
standby 2 preempt
interface FastEthernet0/0.13
encapsulation dot1Q 13
ip address 10.105.41.130 255.255.255.128
standby 3 ip 10.105.41.129
standby 3 priority 105
standby 3 preempt
interface FastEthernet0/0.14
encapsulation dot1Q 14
ip address 10.105.42.2 255.255.255.0
standby 4 ip 10.105.42.1
standby 4 priority 105
standby 4 preempt
interface FastEthernet0/0.101
description ****Existing Technical SRV Zone Subnet ************
encapsulation dot1Q 101
ip address 192.0.100.11 255.255.255.0
standby 5 ip 192.0.100.10
standby 5 priority 105
standby 5 preempt
interface FastEthernet0/0.102
description ****Existing Tech DMZ Subnet****
encapsulation dot1Q 102
ip address 10.104.9.11 255.255.255.0
standby 6 ip 10.104.9.10
standby 6 priority 105
standby 6 preempt
interface FastEthernet0/0.103
description ****Existing Comverse Subnet****
encapsulation dot1Q 103
ip address 192.9.205.11 255.255.255.0
standby 7 ip 192.9.205.10
standby 7 priority 105
standby 7 preempt
interface FastEthernet0/0.104
description ****Existing Vlan****
encapsulation dot1Q 104
ip address 192.0.196.11 255.255.255.0
standby 8 ip 192.0.196.10
standby 8 priority 105
standby 8 preempt
interface FastEthernet0/1
no ip address
duplex full
speed 100
interface Serial0/0/0:0
description **** E1link to AND_DR02_HYD ****
ip address 10.254.238.6 255.255.254.0
encapsulation ppp
interface Serial0/0/1:0
no ip address
ip classless
ip route 0.0.0.0 0.0.0.0 192.0.100.13
ip route 10.105.3.0 255.255.255.0 Serial0/0/0:0
5 Replies 5
smothuku
Level 7
Level 7
sorry for lenghty config....
R2 router:
interface GigabitEthernet0/0
description CONNECTED TO AND_CS01_HYD
ip address 10.105.3.9 255.255.255.128
no ip proxy-arp
duplex full
speed 1000
media-type rj45
no negotiation auto
standby 2 ip 10.105.3.7
standby 2 preempt
interface GigabitEthernet0/1
description CONNECTED TO AND_DR01_HYD
no ip address
no ip proxy-arp
duplex full
speed 1000
media-type rj45
no negotiation auto
description **** E1link to AND_DR02_ABI ****
ip address 10.254.238.9 255.255.254.0
encapsulation ppp
ip classless
no ip route static inter-vrf
ip route 0.0.0.0 0.0.0.0 Serial0/0/0:0
ip route 10.104.9.0 255.255.255.0 10.254.238.10
ip route 10.105.40.0 255.255.255.0 10.254.238.10
ip route 10.105.41.0 255.255.255.0 10.254.238.10
ip route 10.105.42.0 255.255.255.0 10.254.238.10
ip route 192.0.100.0 255.255.255.0 10.254.238.10
ip route 192.0.196.0 255.255.255.0 10.254.238.10
ip route 192.9.205.0 255.255.255.0 10.254.238.10
1.when i am trying to ping serial ip (10.254.238.9 and 10.254.238.9) from 2950 switch , it is not pinging.
2.I am not able to reach 10.105.3.1 (host connected to 3750 switch which is in vlan) from siwtch as well as R1 router.
Is there any wrong in the config.
satish
Shouldn't be the Switch 2950 fa0/3 in 802.1q trunk since the Router R1 fa0/0.14 is encapsulated to 802.1q?
i.e.
switchport mode trunk
Hi Medan,
Thanks you very much for reply and info.
Suppose if i want use f0/3 of 2950 switch in val14 what could be the config of 2950 and R1 router.(i don't want to use f0/3 as trunk port)
Can you give me an example of configuring vlan between 2950 switch and 2811 router.
Cheers,
satish
Hi Satish,
Don't use sub-interface with encapsulation or sub-interface in R1. But your R1 sub-interfaces are in HSRP with another Router?
Else, find another port in Switch 2950 that you can connect to R1 and trunk
Dandy
Satish,
Create a trunk between R1's port and the 2950 switchport. Also configure the Native vlan as 11 on the trunk link, otherwise the link will not work properly and you will see a lots of issue.once the trunk is up, you should be fine.
-amit singh
