VLAN Load Balancing with HSRP
sdasgupta
Hi All,
I have tried to configure in such a way, so that 2 no.s of Core switch ( 4506 ) can act with ACTIVE-ACTIVE mode. I configred all odd VLAN's with high priority in Core-1 & all even VLAN's with high priority in Core-2, and respective odd or even VLAN's with low priority in Core-1 & Core-2 switch.
Now, that problem is.......I test the setup by Power ON & OFF both switches which are working fine. But, let say I keep admin shut down one of the odd vlan in Core-1, all the user in that VLAN can access only the odd VLAN's, can't communicate with even VLAN's at that time and vis-a-vis for even vlan can only act with even vlan only not with odd vlan.
My question.....is it fine and working like that only ....or any config with VLAN / Switch configure. Along with please also confirm if the config is fine for VLAN load balance in 2 Core switch.
NB:- The problem occures when I keep any odd / even VLAN in admin down mode for their high priority Switch. But working fine with all communication if any of the switch goes power off.
I have attached the config for Core-1 & Core-2 with related information.
15 Replies 15
Is your problem solved mate??
