VLAN migration on layer 2 help
nishxx7x
Visitor
We have Access switches configured as Layer 2.  Issue is migrating away from default VLAN1, some switches have default VLAN 1 on the ports, some are setup with VLAN 1 as management interface IP and some are using both.  The default gateway is forwarded to core switch and to firewall were this VLAN 1 is sitting.
We are planning to migrate legacy switch to new C9200/C9300 and trying to move away from Vlan1.  Need help, what is best way to do this in phase approach as we can't do all switches at same time, also access points are on VLAN 1 as well.
M02@rt37
Hello @nishxx7x
One approach is to introduce new vlan (users, AP, management) across core and access while keeping vlan1 temporarily, then migrate gradually... First create SVIs and Gw on the core/firewall for new vlan, trunk them to all switches, then move management IP off vlan1 to a dedicated vlan (...99), then migrate access ports and APs one by one to their new vlan ensuring DHCP and routing are ready.
During the transition vlan1 stay active for legacy devices, and once everything is moved you then emove vlan1 from trunks and access ports to fully decommission it without service disrupton !!!
Best regards
Mark Elsen
  - @nishxx7x                     You can create other vlans for user and application purposes
                                           but do not delete vlan1 on switches ;
                                           It’s used for control-plane protocols (like CDP, VTP, sometimes STP)
  M.
-- ' Listen to the wind, it talks
          Listen to the silence, it speaks
             Listen to your heart, it knows
Ganado Mucho (1809 to 1893 ) Navajo Indian
Joseph W. Doherty
There are a couple of techniques that can be used to assist in similar migrations.
The first technique, somewhat common, is to run two subnets on the same VLAN.  This allows you to reassign some IPs so when it comes time to place the two subnets into their own VLANs, the port to VLAN reassignments are minimal and everything has already been assigned IPs as desired.
The other technique, I believe uncommon, would be to connect two logical VLANs, into a single L2 domain.  This would usually allow port VLAN reassignments without changing IPs.
The two techniques could be used at the same time.
Both techniques require a good understanding of them to be used well and ideally they are only used temporarily for a transition.
The last technique is figuring out what needs to be changed, how to do it as quickly as possible, and then just do it during a scheduled outage.
