Vlan Network Configuration on Layer 3 Switch
NewbieCCNA
Visitor
Is it uncommon to use just vlans on switch interfaces/ports instead of ip addresses? When I went through the Cisco classes I remember we used ip addresses on the interfaces, whether it was a LAN connection or between other switches and routers. We used vlans too and also assigned ip addresses to the interfaces.
I now work for a company in IT where it looks like just 1 interface to another switch has an ip address when I do a "show run" from our 6500-E series layer 3 switch that has about 144+ ports on it. These ports lead to end devices or other switches. We have about 15 more switches and really I have just seen an ip address for vlan 1 so that we can log onto it and manage it. The rest of the ports are in various vlans.
I am about to set up a new small business network for a friend and will use 2 2960s switches and confused if I should put ip address on interfaces like we had done in my Cisco training or just use vlans to put the access ports in. I will be using about 3 vlans.
Any guidance would be appreciated.
Georg Pauwen
in general, you put physical interfaces in VLANs, and you use VLAN interfaces for layer 3 routing.
Putting IP addresses on physical interfaces is usually done to connect other layer 3 devices which are directly connected to that port/device.
Below is a typical switch configuration sample:
interface FastEthernet0/0
switchport access vlan 10
spanning-tree portfast
interface FastEthernet0/1
switchport access vlan 20
interface FastEthernet0/2
switchport access vlan 30
interface Vlan 10
ip address 192.168.10.1 255.255.255.0
interface Vlan 20
ip address 192.168.20.1 255.255.255.0
interface Vlan 30
ip address 192.168.30.1 255.255.255.0
Is that what you are asking ?
Georg Pauwen
interface Vlan 10
interface Vlan 20
interface Vlan 30
Thank you for the response. That does make sense and I took another look at my Cisco books and they do show routers with IP addresses, not the switches. Because our switch is used also as a router that got me a bit confused. For our Cisco classes/labs we mainly used Layer 2 switches and routers, not layer 3 switches that did the routing.
I appreciate you taking the time to explain and remind me.
