VLAN not working
icoltus
Community Member
Hi! I'm doing a simple network of 1 router, 3 switches, 3 servers and 3 hosts. The router assigns dynamics IP's to the hosts through OSPF and inside the swtiches I have two VLAN's defined (40 and 50), the vlan 40 which corresponds to the switch 0 and hosts PC1 and Smartphone can connect via ping to the servers or to the router, contrary to that the vlan 50 cant ping to any other host or server, I wanted to know what am I doing wrong.
Right now, I can see that the message doesn't even "get" to the router and I don't know why because it has the smae configuration as the other swtich.
Thanks for the help in advance!
The files uploaded are the config files of the router the Swtich0 (Vlan40) and the Swtich1 (Vlan50) which is the one failing, I have also uploaded an image of the network.
Hello
You have defined on the rtr the correct sub-interfaces for vlans 40-50, however your dhcp scope doesn't related to either of vlan 40 or 50.
This shouldn't stop connectivity it will only negate hosts from obtaining dhcp correctly if not at all - so you would have to manually apply the correct addressing for each host to communicate with each other.
I see trunks on each switch, I am assuming theses are for switch-to switch connectivity and also for switch 0 to rtr connectivity?
Your dhcp scope should be
Vlan 40
ip dhcp pool netB
 network 192.168.20.0 255.255.255.0
 default-router 192.168.20.1
Vlan 50
ip dhcp pool netA
network 192.168.30.0 255.255.255.0
default-router 192.168.30.1
or
interface GigabitEthernet0/1.50
 encapsulation dot1Q 50
 ip address 10.0.0.1 255.0.0.0
res
Paul
Kind Regards
Paul
Reza Sharifi
Can you post the config for switches (sh run) and the router?
What is the output of "sh vlan summ" from the switches?
These are the files you asked for
Hello
Vlan 40
ip dhcp pool netB
Vlan 50
ip dhcp pool netA
or
res
Paul
Kind Regards
Paul
