vlan on 2960s catalyst
halooos111
hallo Community,i need your help
i have a Catalyst 2960S since 2 days iam a new user, i like to configure the switch!
my first problem is: i have 2 vlan vlan1/24 and vlan200/24 i'd like to cofig port1 to be tagged on the 2 vlans i know from hp port must be tagged
how can i config port 1 to be tagged on vlan1 and vlan200? and port 2 to be untagged in vlan1 and untagged in vlan200?
can some body help?
thank you very much
best regards Tony
12 Replies 12
Leo Laohoo
Tagged VLAN:
conf t
interface G 1/0/
switchport mode trunk
switchport trunk  allowed
end
wr
UN-Tagged VLAN:
conf t
interface G 1/0/
switch access vlan
end
wr
thank you for the answer,
but i still have the problem in vlan200!!
vlan1 is my default vlan
in vlan200 there is a dhcp server,
i connect the switch to the LAN through port 1, how can i configure port one so that the switch can communicate on the 2 vlans?
on port 2 i have connected my apple and i didnot become an ip adress from the dhcp server
how shall i config port 2?
thank u
best regards Tony
Hi Tony,
Please config like below..
#interface -->interface number to which you connect the switch
#switch port mode trunk
#switchport trunk  allowed vlan 200 --> so on you can if you want any other vlan like vlan 1
#interface -->interface number to which you connect your laptop
#switchport access vlan 2
Please rate the helpfull posts.
Naidu.
An access port can only be a member of 1 VLAN either VLAN 1 ( default) or VLAN 200 with the switchport access vlan 200
interface command.
If you want some client connected to a port in 1 VLAN to get an IP address via DHCP from a server in another VLAN then
you must configure ip helper-address command under the interface VLAN  which the client is a member of.
example: client connected to a port in VLAN 1
-interface vlan 1
ip address x.x.x.x y.y.y.y.y
ip helper-address x.x.x.x  where x.x.x.x is the ip address of DHCP server.
Regards.
Alain
Hi Tony,
Yes, you need the ip helper command inorder to forward the dhcp broadcast request from the respective vlan to dhcp server. So it must be like below example...
in vlan200
ip address 10.10.10.1
ip helper-address "dhcp server ip"
Naidu.
in vlan200 (10.10.200.0/24)
i have a dhcp server
ip adress 10.10.200.1
and thats my problem how can i config port 2 in vlan200 so that my lap becomes an ip= 10.10.200.3
the cisco switch(port1) is connected to a hp switch(port3) so i think i have to config cisco port1 to be tagged on vlan1 and vlan200 then i can config cisco port2 to be untagged in vlan200 because when i untagged port2 on vlan200 i will directly become an ip from the dhcp server or what do u think? (see my attachment),
in this case you have nothing special to do as your client is in same vlan as the server.
so just do this on the Cisco switch:
on port 1:
on port 2:
switchport mode access
Just make sure the native vlan is the same on the HP and Cisco for the trunk link between the 2 devices.
Regards.
Alain
Hey thank you for the tipps,
on port 1 the trunk works, but on port 2 i am still have no connection to the dhcp server.
ASA 5510 is doing the routing
best regards
Tony
where is the ASA in your topology, I didn't see it.
Repost a full topology and full configs.
Regards.
Alain
i would like to config the cisco to work like the hp switches because by and by i want to change to cisco.
so i still have the question:
how i tagged the 2960 in vlan1 aund vlan2
and
how i untagged the pc in vlan1 and the mac in vlan2
ps i have made the upgrad of the IOS.
best regards
Tony
hey,
have u seen the topology?
Leo Laohoo
And who's doing your routing?
Oh well, you have a 2960.  Upgrade the IOS to 12.2(55)SE1 or later and you  have limited static routing functionality.
