Vlan overlapping
network
Community Member
hi all,
i have three vlan as mentioned below-
int vlan 80
ip add 10.101.108.129 255.255.255.224
int vlan 90
ip add 10.101.108.161 255.255.255.224
int vlan 100
ip add 10.101.108.193 255.255.255.224
my prob is i want to delete this two vlan 90 & 100 and want to make one another vlan called vlan 120
int vlan 120
ip add 10.101.108.161 255.255.255.192
but whenever i try to do so it gives a error- 10.101.108.128 overlapping vlan 80.
and does not allow to give ipp add to vlan 120.
plz suggest
2 Accepted Solutions
ssieger
Level 3
Level 3
the range of vlan 80 is 10.101.108.129-158, and the range of vlan 120 is 10.101.108.129-190. So the range of host addresses is overlapping. It's early morning here in germany, hope i'm right...:-)
Greetings, Stephan
vaisharm
int vlan 80
The above vlan is for IPs from .129-.159
10.101.108.129 - Network ID
10.101.108.130 - First Host
10.101.108.158 - Last Host
10.101.108.159 - Broadcast ID
int vlan 120
The above vlan is for IPs from .129-.191
10.101.108.190 - Last Host
10.101.108.191 - Broadcast ID
This explains the overlap - IPs from .129-.159 are a part of VLAN 80 already.
You may use the network 10.101.108.192/26 for VLAN 120.
~Vaibhav
ssieger
Level 3
Level 3
Greetings, Stephan
vaisharm
int vlan 80
int vlan 120
~Vaibhav
