Vlan problem with Cat6500 SUP-32
michelerossi
I' ve configured into a cat6500 2 vlan layer3:
vlan 12: 192.168.0.1/24
vlan 16: 172.16.0.1/24
I've associated into the switch some ports into the vlan 12 with "switchport access valn 12" command and other ports into a vlan 16 with "switchport access valn 16" command.
If I attach My Pc with ip address 192.168.0.2/24 into a port associated in the Vlan 16, I succeed to ping the other Pc connected into the ports associated in the Vlan12 correctly with the class 192.168.0.x.
If I do a "show vlan", my port is associated into a vlan 16,while if i do "show arp", I see that the port is associated int a Vlan 12:
Internet 192.168.0.2 0 0012.3f0f.da5d ARPA Vlan12.
How is it possible ?
A vlan is a broadcast domain and I can do This with interVlan Switching if I attached my pc in the correct port associated in my vlan 12.
I don't see my network ip addresses If i connect my Pc in a port associated into another Vlan.
Best Regards
Michele
Probably You must reload th switches.
mahmoodmkl
Level 7
Level 7
Can u post sh run
Mahmood
The real topology is this:
I' ve two cisco WS-C6504-E connected to a Port-channel and they have configured with GLBP. But I've the same problem if I isolated one WS-C6504-E and My pc is attached into this Catalyst.
i put in shutdown the port-channel and I clear GLBP in this switch and I've the same problem.
I attached the configurations.
Best Regards
