Vlan Problem
cbaze
Visitor
I have 2 Cisco CBS350 switches. They are connected by fiber. I am trying to setup a VLAN (20) on port 1 of each switch to isolate the 2 machines so they can only see each other. I have create VLAN 20 on each switch. I have setup each fiber port as Trunked with with access to both VLANS ( 1U, 20T ). I then setup port 1 on each switch as access to VLAN 20 ( 20U ). These 2 machines will not see each other.
Remove this one more and test please
interface TenGigabitEthernet1/0/1
no macro auto
32 Replies 32
 When you say not see each other do you mean ping or are you trying another way?
Yes ping. On VLAN 1 they ping just fine.
Do you have access via CLI ? Would be Nice see the show running!
Do you want to see the entire show running?
that would be great.
config-file-header
IT-CBS350-24T
v3.3.0.16 / RCBS3.3_950_377_202
CLI v1.0
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
unit-type-control-start
unit-type unit 1 network gi uplink te
unit-type unit 2 network gi uplink te
unit-type unit 3 network gi uplink te
unit-type unit 4 network gi uplink te
unit-type-control-end
vlan database
vlan 20
exit
voice vlan state auto-triggered
voice vlan oui-table add 0001e3 Siemens_AG_phone
voice vlan oui-table add 00036b Cisco_phone
voice vlan oui-table add 00096e Avaya
voice vlan oui-table add 000fe2 H3C_Aolynk
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone
voice vlan oui-table add 00e075 Polycom/Veritel_phone
voice vlan oui-table add 00e0bb 3Com_phone
dot1x system-auth-control
dot1x mac-auth eap username groupsize 2 separator : lowercase
bonjour interface range vlan 1
hostname IT-CBS350-24T
encrypted radius-server host 10.5.19.44 key +kcLT6/E8WI+PuwsVO
aaa accounting dot1x start-stop group radius
passwords aging 180
username
ip telnet server
interface vlan 1
ip address 10.5.19.70 255.255.255.0
no ip address dhcp
interface GigabitEthernet1/0/1
dot1x authentication 802.1x mac
dot1x port-control auto
spanning-tree link-type point-to-point
macro description switch
!next command is internal.
macro auto smartport dynamic_type switch
interface GigabitEthernet1/0/2
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
switchport access vlan 20
switchport trunk native vlan 20
switchport trunk allowed vlan 20
interface GigabitEthernet1/0/10
switchport general pvid 20
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
switchport mode trunk
switchport trunk allowed vlan 1,20
exit
macro auto controlled
config-file-header
IT-CBS350-24T
CLI v1.0
ssd-control-start
ssd config
vlan database
vlan 20
exit
encrypted radius-server host xxxkey xx
passwords aging 180
username
ip telnet server
interface vlan 1
no ip address dhcp
exit
I have added it twice but it keeps getting removed from here for some reason.
You can save the config in a txt file and attach file here.
But I could see your config. This diagram below is what you are trying to accomplish right?
What I would recommend is first clean up the interfaces involved.
conf t
default interface <interface>
Then, config the interface with the minimum necessary
Interfaces between switches:
conf t
int gx/x
switch port mode trunk
Interface between switches and PCs.
conf t
int gx/x
switchport mode acess
switch access vlan 20
Let's see if this works. Here is what I think you want to see:
Switch 1
VLAN Setup:
interface vlan 1
no ip address dhcp
interface vlan 30
name Test
Trunk Port:
switchport trunk allowed vlan 1,30
Access Port:
switchport access vlan 30
switchport general pvid 30
switchport trunk native vlan 30
Switch 2
interface vlan 1
ip address 192.168.168.1 255.255.255.0
no ip address dhcp
interface vlan 30
name Test
Trunk Port:
interface TenGigabitEthernet1/0/22
Access Port
interface TenGigabitEthernet1/0/24
speed 1000
Thanks.
 First you need to device by vlan 20 or 30.  Initially you mentioned 20.
If you want to make the switch as layer3, which means the switch will have IP address on the vlan and differents vlans to communicate, you need to run the command:
conf t
ip routing
Then, on the vlan you need to do:
int vlan 20
 ip add x.x.x. x x.x (choose the ip address and mask)
Do it on both switches. Keep in mind that vlan 1 will not participate on this.
I will give here and example
Switch 1
conf t
int vlan 20
ip add 192.168.20.1 255.255.2550
switch 2
int vlan 20
ip add 192.168.20.2 255.255.255.0
Use the IP add 192.168.20.3 and 192.168.20.4 on the PCs.
For the interface config, use the following example
conf t
conf t
int gx/x
conf t
int gx/x
I changed it to 30 testing. End result I just want 1 port on each switch to be able to communicate with each other on VLAN 30. Does this require Layer 3 if I do not need any other subnets to route to this? It doesn't seem to be as hard and it is being for me!
It does not required layer3 on the switch
You need to create vlan 30 on both switch
Add vlan 30 on trunk between switches
You need to put both PC interface on vlan 30
Add IP on PCs.
Thats it.
I feel like that is exactly what I am doing. Your diagram looks like what I want. I will try what you suggested and keep you posted. Thanks for the help so far!
