VLAN Pruning Cisco 9300
DavidLauterbach
Community Member
Is Vlan Pruning automatically enabled on Cisco 9300 Switches?
lagerplane
Level 3
Level 3
By Vlan Pruning you mean VTP Pruning? If so, then that is disabled by default even when you enable VTP on your Switch.
In case you mean Vlan Pruning as in pruning the allowed vlans on a trunk port, that is enabled as in the port is capable of doing that on its own (via VTP Pruning or STP). Or you could also manually list the allowed vlans on the trunk.
balaji.bandi
i would say YES/NO - it  depends on the config on the switch -
BB
can you more elaborate ?
