vlan pruning issue
davegibelli
I have a 3750 connected to a 2960 with 43 vlans but it is vlan 70 that has an issue. The 3750 is the root bridge using rstp and the 2960 has the 3750 as the root via port g0/1. But the 2960 has pruned vlan 70 from the trunk to the 3750!
Why would a switch prune a vlan from a trunk port with the root bridge on it, it does not make sense.
10 Replies 10
Antonio Knox
Level 7
Level 7
post the output of the following from the 3750:
sh spanning vl 70 | i VLAN|Root|the root
And on the 2960:
sh int trunk
sh vl br
sh run int gi0/1
sh vtp status
  Please post the output of "show vlan" on C2960. Does C2960 assign VLAN-70 to any ports? Does C2960 have VLAN-70 pass through any trunk ports? Please post the output of "show interface trunk" on C2960.
HTH,
Toshi
3750
CAT3750G-F2-CORE#sh sp vl 70 | i VLAN|Root|the root
VLAN0070
  Root ID    Priority    4166
             This bridge is the root
2960
CAT2960-PBX-01#sh int trun
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         trunking      1
Gi0/3       on               802.1q         trunking      1
Port        Vlans allowed on trunk
Gi0/1       1-4094
Gi0/3       1-4094
Port        Vlans allowed and active in management domain
Gi0/1       1-2,5,14,17,20,56,70,73,76,98-101,107,110-113,121,123-124,130,140-14
3,150-153,160-163,172,180-183,212
Gi0/3       1-2,5,14,17,20,56,70,73,76,98-101,107,110-113,121,123-124,130,140-14
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       1-2,5,14,20,73,76,99-101,107,110-113,121,123-124,130,140-143,150-153
Gi0/3       1,5,70,73,76,100,130,140-141
CAT2960-PBX-01#sh vl id 70
VLAN Name                             Status    Ports
70   VLAN0070                          active    Gi0/1, Gi0/3
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
70   enet  100070     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Primary Secondary Type              Ports
CAT2960-PBX-01#sh span vl 70 | i VLAN|Root|the root
VLAN0070
Gi0/1               Root FWD 4         128.49   P2p
CAT2960-PBX-01#sh vl br
1    default                          active    Gi0/2, Gi0/4
2    VLAN0002                 active
5    VLAN0005                         active    Fa0/23
14   VLAN0014                         active
17   VLAN0017                         active
20   VLAN0020                   active
56   VLAN0056                         active
70   VLAN0070                          active
73   VLAN0073                        active
76   VLAN0076                           active
98   VLAN0098                         active
99   VLAN0099                         active
100  Printers                         active    Fa0/4, Fa0/15, Fa0/29, Fa0/40
101  Printers-1                       active    Fa0/44
107  VLAN0107                         active
110  Printers-1stfloor                active
111  Printers-1st                     active
112  VLAN0112                         active
113  printers-1st-floor               active
121  Printers-2ndfloor                active
123  printers-2nd                     active
124  Printers-2nd                     active
130  VLAN0130                         active    Fa0/16
140  Grnd-Fl-Data                     active    Fa0/1, Fa0/2, Fa0/3, Fa0/5
                                                Fa0/6, Fa0/7, Fa0/8, Fa0/9
                                                Fa0/10, Fa0/11, Fa0/12, Fa0/13
                                                Fa0/14, Fa0/17, Fa0/18, Fa0/19
                                                Fa0/20, Fa0/21, Fa0/22, Fa0/24
                                                Fa0/25, Fa0/26, Fa0/27, Fa0/28
                                                Fa0/30, Fa0/31, Fa0/32, Fa0/33
                                                Fa0/34, Fa0/35, Fa0/36, Fa0/37
                                                Fa0/38, Fa0/39, Fa0/41, Fa0/42
                                                Fa0/43, Fa0/45, Fa0/46, Fa0/47
                                                Fa0/48
141  Grnd-Fl-Voice                    active    Fa0/1, Fa0/2, Fa0/3, Fa0/4
                                                Fa0/5, Fa0/6, Fa0/7, Fa0/8
                                                Fa0/9, Fa0/10, Fa0/11, Fa0/12
                                                Fa0/13, Fa0/14, Fa0/15, Fa0/17
                                                Fa0/18, Fa0/19, Fa0/20, Fa0/21
                                                Fa0/22, Fa0/23, Fa0/24, Fa0/25
                                                Fa0/26, Fa0/27, Fa0/28, Fa0/29
                                                Fa0/38, Fa0/39, Fa0/40, Fa0/41
                                                Fa0/42, Fa0/43, Fa0/44, Fa0/45
                                                Fa0/46, Fa0/47, Fa0/48
142  Grnd-Fl-Wireless                 active
143  Grnd-Fl-GWireless                active
150  1st-Fl-Data                      active
151  1st-Fl-Voice                     active
152  1st-Fl-Wireless                  active
153  1st-Fl-GWireless                 active
160  2nd-Fl-Data                      active
161  2nd-Fl-Voice                     active
162  2nd-Fl-Wireless                  active
163  2nd-Fl-GWireless                 active
172  VLAN0172              active
180  Unit4-6-Data                     active
181  Unit4-6-Voice                    active
182  Unit4-6-Wireless                 active
183  Unit4-6-GWireless                active
212  VLAN0212                         active
1002 fddi-default                     act/unsup
1003 trcrf-default                    act/unsup
1004 fddinet-default                  act/unsup
1005 trbrf-default                    act/unsup
CAT2960-PBX-01#sh run int g0/1
Building configuration...
Current configuration : 255 bytes
interface GigabitEthernet0/1
description 1Gbps Link to 2nd Floor Core switch CAT3750G-F2-CORE G2/0/50
switchport mode trunk
srr-queue bandwidth share 10 10 60 20
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
end
CAT2960-PBX-01#sh vtp stat
VTP Version capable             : 1 to 3
VTP version running             : 3
VTP Domain Name                 : BDC-VTP-Domain
VTP Pruning Mode                : Enabled
VTP Traps Generation            : Disabled
Device ID                       : b414.89c9.5f00
Feature VLAN:
VTP Operating Mode                : Client
Number of existing VLANs          : 45
Number of existing extended VLANs : 0
Configuration Revision            : 42
Primary ID                        : ecc8.8221.2180
Primary Description               : CAT3750G-F2-CORE
MD5 digest                        : 0x7D 0xB1 0x94 0xDA 0xA0 0xFC 0x7C 0x0F
                                    0x76 0x25 0xE0 0x7B 0x97 0x2E 0x12 0x9C
Feature MST:
VTP Operating Mode                : Transparent
Feature UNKNOWN:
   Please post "show cdp neighbor" and "show run int g0/3" on C2960.  I just want to know which devices are connecing to C2960. not just C3750. And That device has used VLAN-70 or not.
Toshi
CAT2960-PBX-01#sh cdp nei
Capability Codes: R - Router, T - Trans Bridge, B - Source Route Bridge
                  S - Switch, H - Host, I - IGMP, r - Repeater, P - Phone,
                  D - Remote, C - CVTA, M - Two-port Mac Relay
Device ID        Local Intrfce     Holdtme    Capability  Platform  Port ID
CAT2960-PBX-02
                 Gig 0/3           176              S I   WS-C2960- Gig 0/3
SEPe05fb9c4b086  Fas 0/13          130             H P M  IP Phone  Port 1
SEPc471fe43a13b  Fas 0/37          141             H P M  IP Phone  Port 1
SEPe05fb9c4a960  Fas 0/19          124             H P M  IP Phone  Port 1
SEPe05fb9c4a824  Fas 0/14          165             H P M  IP Phone  Port 1
SEPe05fb9c4a944  Fas 0/23          134             H P M  IP Phone  Port 1
SEPe05fb9c4a946  Fas 0/27          165             H P M  IP Phone  Port 1
SEPe05fb9c4a821  Fas 0/7           143             H P M  IP Phone  Port 1
SEPe05fb9c4ac4b  Fas 0/2           174             H P M  IP Phone  Port 1
SEP588d09724f5e  Fas 0/34          164             H P M  IP Phone  Port 1
SEPe05fb9c4ac3f  Fas 0/9           174             H P M  IP Phone  Port 1
SEPc471fe43a19a  Fas 0/18          159             H P M  IP Phone  Port 1
SEPe05fb9c4ad1d  Fas 0/10          142             H P M  IP Phone  Port 1
SEPe05fb9c4ab4e  Fas 0/22          121             H P M  IP Phone  Port 1
SEP588d09724db7  Fas 0/30          177             H P M  IP Phone  Port 1
SEPe05fb9c4ae08  Fas 0/21          140             H P M  IP Phone  Port 1
SEPe05fb9c4a78e  Fas 0/33          177             H P M  IP Phone  Port 1
SEPe05fb9c4ac40  Fas 0/12          120             H P M  IP Phone  Port 1
SEPe05fb9c4aefd  Fas 0/5           134             H P M  IP Phone  Port 1
SEPc471fe4379e2  Fas 0/17          144             H P M  IP Phone  Port 1
SEPe05fb9c4ad31  Fas 0/8           166             H P M  IP Phone  Port 1
SEPc471fe43748e  Fas 0/31          154             H P M  IP Phone  Port 1
SEPe05fb9c4ae07  Fas 0/24          158             H P M  IP Phone  Port 1
SEPe05fb9c4aefa  Fas 0/11          137             H P M  IP Phone  Port 1
CAT3750G-F2-CORE
                 Gig 0/1           144             R S I  WS-C3750G Gig 2/0/50
CAT2960-PBX-01#sh run int g0/3
Current configuration : 252 bytes
interface GigabitEthernet0/3
description 1Gbps Link to Gnd Floor Access switch CAT2960-PBX-02 G0/3
queue-set 2
priority-queue out
mls qos trust cos
auto qos voip trust
end
   Okay CAT2960-PBX-01 has not assigned VLAN-70 to any active ports. Time to check CAT2960-PBX-02.  It's the same thing. If CAT2960-PBX-02 has not assigned VLAN-70 to any active ports and no VLAN-70 passed through trunk ports. CAT3750G-F2-CORE should prune VLAN-70 on G0/1.
   Please post "show vlan" , "show cdp neighbor" , "show vtp status" and "show interface trunk" on CAT2960-PBX-02.
   I have to do this because I want to make sure that pruning is working correctly or not.
Toshi
I noticed that in your vtp status (2960) you have pruning enabled.  This feature is inherited from the VTP server.
If you connect a host on a Vlan 70 assigned access port vlan 70 will no longer be pruned on the trunk(s).  This is actually the way that pruning is supposed to work.  If there are no ports associated with a particular vlan on the switch that vlan will be pruned on the trunk.  If you notice in the 'show int trunk' output vlan 70 is only missing in the 'Vlans in spanning tree forwarding state and not pruned' section.
More on VTP Pruning:
http://www.cisco.com/en/US/tech/tk389/tk689/technologies_tech_note09186a0080094c52.shtml#vtp_pruning
Hope that helps.
thotsaphon/Antonio
You can see that the next switch has not pruned vlan 70
I cannot believe a switch should prune a vlan if it does not have any access port in a vlan but a trunk passing through does have mac addresses in vlan 70.
Either I am missing something obvious or this is a bug in the version of ios or the 2960 hardware!
Pruning is only supposed to stop unknown traffic from being broadcast down a trunk that has NO mac addresses as the next switch has no active ports in the vlan. This is not the case here.
CAT2960-PBX-02#sh int trun
Gi0/1       1-4094
Gi0/3       1-4094
This is very odd, the switch is a client but it has a different setting for pruning to all the others in the vtp domain - why?
CAT2960-PBX-02#sh vtp stat
VTP Pruning Mode                : Disabled     <---------------------------------------------
Device ID                       : f025.72de.2a80
Feature VLAN:
VTP Operating Mode                : Client    <-----------------------------------------------
Feature MST:
Feature UNKNOWN:
You should check the config revison and the number of vlans on the vtp server and other clients to see if they are the same.
Then create a dummy vlan and delete it again on the vtp server. The config rev should now increase on all clients.
If not, there may be an incorrect vtp password on switch CAT2960-PBX-02 which will prevent it from receiving updates.
The command: "sh vtp passw" will show the current password if any.
regards,
Leo
