VLAN routing issue
FloridaGAL
Community Member
Here's my setup
3 Networks across 3 switches (3x C3650)
10.7.64.1.x/24 (Vlan 7)
10.10.10.x/24 (Vlan 20)
192.168.1.x/24 (Vlan 15)
The switches are all connected to each other, with Switch one have a connection to an ASA and the outside world.  My goal is to get all three switches communicating via Layer 2 by using the 10.10.10.x network as a bridge to connect the other two networks.
Each switch has one switchport that exists in the 10.10.10.x network (.1 for Switch 1, .2 for Switch 2, .3 for Switch 3).
I currently have a route in Switch 1 that is as follows:
ip route 192.168.1.0 255.255.255.0 10.10.10.3
I have a route in Switch 3 that is as follows:
ip route 10.7.64.1.0 255.255.255.0 10.10.10.1
From the 192.168.1.x network I can ping everything perfectly in the 10.10.10.x and 10.7.64.x networks.  However, I can ONLY ping the SVI for VLAN 15 (192.168.1.1) and the network id (192.168.1.0) from the 10.7.64.x network on Switches 1&2.
Right now there is a trunk between Switches 1&2 and a trunk between Switches 1&3.  On both trunks Vlan access is being granted to Vlans 7,20 and 15.
This really has me stumped as to why I can't have complete bi-directional communication.  Can anyone assist me in this?
Vlan 20 has interfaces on all switches
I take   it Vlan 15 is on switch 3 and its address 192.168.1.1 is the gateway for that network.
and Vlan 7 is on switch 1 and its address is 10.7.64.1
can you share the relevant configurations
SW1
#sho run Building configuration... Current configuration : 10427 bytes ! ! Last configuration change at 13:37:07 EST Tue Feb 9 2016 by GALIT ! NVRAM config last updated at 13:17:37 EST Tue Feb 9 2016 by GALIT ! version 15.0 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption service compress-config ! ! boot-start-marker boot-end-marker ! ! vrf definition Mgmt-vrf ! address-family ipv4 exit-address-family ! address-family ipv6 exit-address-family ! ! aaa new-model ! ! ! ! ! ! ! ! aaa session-id common clock timezone EST -5 0 clock summer-time EDT recurring switch 1 provision ws-c3650-48ps ip routing ! ip device tracking ! ! ! ! ! ! ! ! ! ! diagnostic bootup level minimal spanning-tree mode pvst spanning-tree extend system-id ! redundancy mode sso ! ! vlan access-map 15 10 action forward ! ! ! class-map match-any non-client-nrt-class match non-client-nrt ! policy-map port_child_policy class non-client-nrt-class bandwidth remaining ratio 10 ! ! ! ! ! ! interface GigabitEthernet0/0 vrf forwarding Mgmt-vrf no ip address negotiation auto ! interface GigabitEthernet1/0/1 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/2 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/3 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/4 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/5 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/6 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/7 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/8 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/9 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/10 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/11 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/12 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/13 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/14 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/15 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/16 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/17 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/18 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/19 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/20 switchport access vlan 20 switchport trunk allowed vlan 7,20 switchport mode trunk ! interface GigabitEthernet1/0/21 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/22 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/23 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/24 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/25 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/26 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/27 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/28 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/29 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/30 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/31 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/32 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/33 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/34 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/35 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/36 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/37 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/38 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/39 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/40 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/41 switchport access vlan 10 switchport mode access spanning-tree portfast ! interface GigabitEthernet1/0/42 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/43 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/44 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/45 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/46 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/47 switchport access vlan 7 switchport mode access switchport voice vlan 10 spanning-tree portfast ! interface GigabitEthernet1/0/48 description SW1 TO SW2 Link switchport trunk allowed vlan 7,10,20 switchport mode trunk ! interface GigabitEthernet1/1/1 switchport access vlan 7 switchport mode access ! interface GigabitEthernet1/1/2 ! interface GigabitEthernet1/1/3 ! interface GigabitEthernet1/1/4 ! interface Vlan1 no ip address shutdown ! interface Vlan7 ip address 10.7.64.1 255.255.255.0 ip helper-address 10.7.64.8 ! interface Vlan15 ip address 192.168.1.1 255.255.255.0 ! interface Vlan20 ip address 10.10.10.1 255.255.255.0 ! ip http server ip http authentication local ip http secure-server ! ip route 0.0.0.0 0.0.0.0 10.7.64.4 ! ! ! ! ! ! ! ! line con 0 stopbits 1 line aux 0 stopbits 1 line vty 0 4 transport input ssh line vty 5 15 transport input ssh ! wsma agent exec profile httplistener profile httpslistener wsma agent config profile httplistener profile httpslistener wsma agent filesys profile httplistener profile httpslistener wsma agent notify profile httplistener profile httpslistener ! wsma profile listener httplistener transport http ! wsma profile listener httpslistener transport https ap group default-group end
SW 3
#sho run
Current configuration : 5542 bytes
! Last configuration change at 10:05:28 UTC Tue Feb 9 2016 by
version 15.0
no service pad
boot-start-marker
boot-end-marker
 address-family ipv4
 exit-address-family
 address-family ipv6
 exit-address-family
logging console emergencies
no aaa new-model
switch 1 provision ws-c3850-24t
ip routing
ip device tracking
qos wireless-default-untrust
system mtu 9198
identity policy webauth-global-inactive
 inactivity-timer 3600
redundancy
 mode sso
 no ip address
 shutdown
 negotiation auto
 switchport access vlan 15
 switchport trunk allowed vlan 1,7,20
interface TenGigabitEthernet1/1/1
interface TenGigabitEthernet1/1/2
interface TenGigabitEthernet1/1/3
interface TenGigabitEthernet1/1/4
interface Vlan1
 no ip address
interface Vlan15
 ip address 192.168.1.2 255.255.255.0
interface Vlan20
 ip address 10.10.10.3 255.255.255.0
ip default-gateway 192.168.1.1
no ip http server
line con 0
 exec-timeout 0 0
 stopbits 1
line aux 0
 stopbits 1
line vty 0 4
 login local
 transport input ssh
line vty 5 15
 login
wsma agent exec
wsma agent config
wsma agent filesys
wsma agent notify
 transport http
 transport https
ap dot11 24ghz rrm channel dca 1
ap dot11 24ghz rrm channel dca 6
ap dot11 24ghz rrm channel dca 11
ap dot11 5ghz rrm channel dca 36
ap dot11 5ghz rrm channel dca 40
ap dot11 5ghz rrm channel dca 44
ap dot11 5ghz rrm channel dca 48
ap dot11 5ghz rrm channel dca 52
ap dot11 5ghz rrm channel dca 56
ap dot11 5ghz rrm channel dca 60
ap dot11 5ghz rrm channel dca 64
ap dot11 5ghz rrm channel dca 149
ap dot11 5ghz rrm channel dca 153
ap dot11 5ghz rrm channel dca 157
ap dot11 5ghz rrm channel dca 161
end
I resolved the issue.  Thanks for checking in to help.
