Vlan Routing
Hi guys,
I need to change the core of the network to move the routing point of a VLAN to two specific routers (I have a several routers onsite and have all L3 switches)
The reason why I need to do this is because the VLAN houses the inside interfaces of the firewalls, and this would ensure that all data flows to the firewalls would be captured by the WCCP functions.
Is there anyway to achieve the above without using Policy based Routing?
Please feel free to share your ideas
Thanks a lot
Jon Marshall
We really need more information.
It would help if we could see a layout or if you could describe it and what traffic flow you want.
For example it could be as simple as moving the SVI but it may be more complicated than that so can you give us some more details.
Jon
