Vlan's routing
Ali27
Hi !
I have an issue on my catalyst 3750
My vlans can't access to the internet, but the inter-vlan routing is ok..
I have a default routeur (zyxel vmg1312-b10a) who is addressed with 192.168.1.254
vlan 1 (default) interface : 192.168.1.10/24
Vlan 10 interface : 172.26.10.254/24
vlan 20 interface : 172.26.20.254/24
vlan 30 interface : 172.26.30.254/24
I can ping the interface where the default router is plug (192.168.1.15) on gi1/0/23
I can ping the interface of vlan
I can ping everything in fact, except the default router and obviously i can't ping 8.8.8.8..
I have a static ip route 0.0.0.0 0.0.0.0 192.168.1.254
When i realized a tracert with vlan 20 (172.26.20.18 to 192.168.1.254) there is an issue.
Tracing route to 192.168.1.254
1) 172.26.20.254 (interface of vlan 20)
2) *      *       *      Requested timed out
Thanks in advance
Seb Rupik
Hi there,
The Zyxel router does not know how to reach the VLAN10,20,30 subnets. You will need to install a static route n the Zyxel directing traffic destined to those subnets via 192.168.1.10 .
This will allow you users to reach the Zyxel inside interface. Your next challenge will be to make the internet reachable to hosts in VLAN10,20,30 . By default the Zyxel will NAT for 192.168.1.10/24, but not the other subnets. You will need to add them to the NAT ACL....assuming it supports it.
cheers,
Seb.
ok, i'll connect to the zyxel first, and i will try different things
