VLAN SLOWNESS between core switch and remote switch
Ronald Jarman
Hello Everyone,
I have issues with slowness when it comes to VLANS and switching.
I have a Core 3560 Switches that takes care of vlan and set as layer 3 switch\router
Fiber Trunk  with encap dot1q
I have a Remote 3560 Switch that has VLAN 171 on the remote locations ports.  This is a 10/100 Switch
When I try to ping  From a pc that is attached to the switch, I do not drop packets but it is a slow ms ping times and we are having issues with database being slow.  I have checked the PC plus checked for updates for the computer.   But we still have the issue on all computers that are within the VLAN.
Here are the ping times that we were able to get from the Dell Comptuer
Reply from 192.168.XX.254 bytes=32 time=497ms TTL=64
Reply from 192.168.XX.254 bytes=32 time=387ms TTL=64
Reply from 192.168.XX.254 bytes=32 time=232ms TTL=64
Reply from 192.168.XX.254 bytes=32 time=674ms TTL=64
Reply from 192.168.XX.254 bytes=32 time=419ms TTL=64
Reply from 192.168.XX.254 bytes=32 time=35ms TTL=64
Reply from 192.168.XX.254 bytes=32 time=542ms TTL=64
This is a contants times between these switches and still have same issues.
Any thoughts would be great!!!
Jeff Van Houten
Level 5
Level 5
Post the configs of both switches.
