vlan span between dell and cisco switch
bbb bbb
Dear Everyone,
Good day
Seeking advice on this scenario in a client environment. We are trying to establish gateway reachability from PC2 connected in Cisco 9300 but not able yield positive result. Trunks are configured on Port-channel where physical interfaces are member of. Access port is also configured for each corresponding port.
Core Switch - Gateway for VLAN 1-5 and 6-10, located in Datacenter1
Dell S5232F-ON - 10G/100G links, connected with trunk (Port-channel), located in Datacenter 2,
Dell S5248F-ON - 1G/10G links, connected with trunk (Port-channel), located in Datacenter2
Cisco 9300 - 1G/10G links, connected with trunk (Port-channel), located in Datacenter2
Configuration at Cisco 9300
Cisco9300#show lldp neighbors
Capability codes:
(R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
(W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Device ID Local Intf Hold-time Capability Port ID
DELL-S5248F-ON Gi1/0/46 120 P,B,R ethernet1/1/6:1
Total entries displayed: 1
Cisco9300#
Cisco9300#sh run int port-channel 120
Building configuration...
Current configuration : 168 bytes
interface Port-channel120
description Cisco 9300<>DELL S5248F-ON
switchport trunk allowed vlan 5,6-10
switchport mode trunk
end
Cisco9300#
Cisco9300#sh run int g1/0/46
Current configuration : 165 bytes
interface GigabitEthernet1/0/46
switchport trunk allowed vlan 5, 6-10
channel-group 120 mode active
end
Cisco9300#sh interfaces trunk
Port Mode Encapsulation Status Native vlan
Po120 on 802.1q trunking 1
Port Vlans allowed on trunk
Po120 5,6-10
Port Vlans allowed and active in management domain
Po120 5,6-10
Port Vlans in spanning tree forwarding state and not pruned
Po120 5,6-10
Cisco9300#
Capability codes:
Cisco9300#
Cisco9300#show run interface g1/0/8
interface GigabitEthernet1/0/8
description link to PC2
switchport access vlan 5
switchport mode access
spanning-tree portfast
end
Configuration at DELL switch S5248F-ON
DELLS5248F-ON# show running-configuration interface port-channel 150
interface port-channel150
no shutdown
switchport access vlan 95
vlt-port-channel 150
DELLS5248F-ON#
DELLS5248F-ON#
DELLS5248F-ON# show running-configuration interface ethernet 1/1/6:1
interface ethernet1/1/6:1
no shutdown
channel-group 150 mode active
no switchport
flowcontrol receive off
DELLS5248F-ON#
DELLS5248F-ON# show vlan 5
Codes: * - Default VLAN, M - Management VLAN, R - Remote Port Mirroring VLANs,
@ - Attached to Virtual Network, P - Primary, C - Community, I - Isolated,
S - VLAN-Stack VLAN
Q: A - Access (Untagged), T - Tagged
NUM Status Description Q Ports
5 Active VLAN5 T Po150
A Eth1/1/46:1
DELLS5248F-ON#
DELLS5248F-ON# show running-configuration interface ethernet 1/1/46:1
interface ethernet1/1/46:1
description link to PC1
no shutdown
DELLS5248F-ON#
DELLS5248F-ON## show lldp neighbors
Loc PortID Rem Host Name Rem Port Id Rem Chassis Id
ethernet1/1/6:1 Cisco9300 Gi1/0/46 c2:1d:80:c2:1d:80
ethernet1/1/46:1 Not Advertised 00:3f:00:00:00:83 00:3f:00:00:00:83
Looking forward to your responses. Best regards
16 Replies 16
You are welcome
MHM
bbb bbb
Dear Everyone,
Thank you for your insights and help. I got back to the remote data center few days back and was able to establish trunk.
On Cisco 9300, port is configured as regular trunk port, port-channel is removed
On Dell S5248-ON, port is configured as regular trunk port, port channel is also removed.
Please see updated configuration below
--------------------- at Cisco9300
Cisco9300#sh run int g1/0/2
Current configuration : 89 bytes
interface GigabitEthernet1/0/2
description Connection to PC2
end
Cisco9300#sh mac ad
Cisco9300#sh mac address-table | i 0/2
5 606d.3cf4.22fa DYNAMIC Gi1/0/2
Cisco9300#
Cisco9300#show spanning-tree vlan 95
VLAN0005
Spanning tree enabled protocol rstp
Root ID Priority 8197
Address d0d0.fd0e.f080
Cost 1055
Port 48 (GigabitEthernet1/0/48)
Hello Time 2 sec Max Age 20 sec Forward Delay 15 sec
Bridge ID Priority 32773 (priority 32768 sys-id-ext 5)
Address 848a.8dc2.1d80
Aging Time 300 sec
Interface Role Sts Cost Prio.Nbr Type
Gi1/0/2 Desg FWD 4 128.2 P2p
Gi1/0/48 Root FWD 4 128.48 P2p
Te1/1/1 Desg FWD 4 128.53 P2p
Cisco9300#
Cisco9300#show interfaces trunk
Gi1/0/48 on 802.1q trunking 1
Gi1/0/48 5,6,10
Gi1/0/48 5,6,10
Gi1/0/48 5,6,10
Cisco9300#
Cisco9300#
Cisco9300#show run int g1/0/48
interface GigabitEthernet1/0/48
switchport trunk allowed vlan 5,6,10
end
Cisco9300#
--------------------- at Dell S5284-ON
S5248F-ON# show running-configuration interface ethernet 1/1/1:1
interface ethernet1/1/1:1
description Connection to PC1
no shutdown
S5248F-ON#
S5248F-ON# show running-configuration interface ethernet 1/1/48:1
interface ethernet1/1/48:1
description Connection to Cisco9300
no shutdown
switchport access vlan 1
S5248F-ON#
S5248F-ON# show spanning-tree vlan 5
Spanning tree enabled protocol rapid-pvst with force-version rstp
VLAN 5
Executing IEEE compatible Spanning Tree Protocol
Root ID Priority 8197, Address d0d0.fd0e.f080
Root Bridge hello time 2, max age 20, forward delay 15
Bridge ID Priority 32773, Address c45a.b134.6505
Configured hello time 2, max age 20, forward delay 15
Flush Interval 200 centi-sec, Flush Invocations 311
Flush Indication threshold 5
Interface Designated
Name PortID Prio Cost Sts Cost Bridge ID PortID
ethernet1/1/1:1 128.8 128 20000 FWD 1051 32863 c45a.b134.6505 128.8
ethernet1/1/5:1 128.40 128 2000 BLK 0 32863 0000.0000.0000 128.40
ethernet1/1/7:1 128.56 128 20000 BLK 1051 32863 c45a.b134.6505 128.56
ethernet1/1/46:1 128.368 128 20000 BLK 1051 32863 c45a.b134.6505 128.368
ethernet1/1/48:1 128.384 128 20000 FWD 1051 32863 c45a.b134.6505 128.384
port-channel140 128.2804 128 50 FWD 1051 32863 c45a.b134.6505 128.2804
port-channel150 128.2814 128 200000000 BLK 1051 32863 c45a.b134.6505 128.2814
Interface
Name Role PortID Prio Cost Sts Cost Link-type Edge
ethernet1/1/1:1 Desg 128.8 128 20000 FWD 1051 AUTO No
ethernet1/1/5:1 Disb 128.40 128 2000 BLK 0 AUTO No
ethernet1/1/7:1 Disb 128.56 128 20000 BLK 1051 AUTO No
ethernet1/1/46:1 Disb 128.368 128 20000 BLK 1051 AUTO No
ethernet1/1/48:1 Desg 128.384 128 20000 FWD 1051 AUTO No
port-channel140 Root 128.2804 128 50 FWD 1051 AUTO No
port-channel150 Disb 128.2814 128 200000000 BLK 1051 AUTO No
S5248F-ON#
Thank you and best regards,
bbb
